Stiff ride
Old Mar 15, 2013 | 07:14 AM
Staged07SS's Avatar
Administrator
Administrator
staged, where do you get those bushings? i'm gonna be changing mine out soon too and would rather upgrade from stock
mine doesnt jerk back and forth either... anymore
Picked them up at Advance Auto the other day.
They are a solid bushing compared to the stock ones which have air voids.
http://www.moogproblemsolver.com/_pd...K10_107_En.pdf
I have MOOG sway bar endlinks, and they work great, so I figured I give their CABs a try.
Old Mar 15, 2013 | 09:06 AM
is your ride any less clunky?
the stiffness i'm ok with... but the crashing creaking clunking sounds not so much
Old Mar 15, 2013 | 09:38 AM
SS89's Avatar
I've been reading good comments on Koni Strut/Shocks, would you guys recommend that I get a suspension package like THIS.
Old Mar 15, 2013 | 09:47 AM
Staged07SS's Avatar
Administrator
Administrator
I haven't installed the CAB's yet. Just got them two days ago.
My car seems to only clunk on damp rainy days.
Installed the endlinks last June, and that took away most of the clunking, but I still have some. That's when I knew it was time to replace the CAB's.
Old Mar 15, 2013 | 09:49 AM
ah ok well i just ordered them too because i'm just getting all sorts of clunks, so F it we'll find out i'm sure most of my suspension is trashed anyways.
Old Mar 15, 2013 | 09:56 AM
Staged07SS's Avatar
Administrator
Administrator
I only have 47k on my struts and shocks.....
My springs are basically brand new (Eibach Pro's), and I replaced the endlinks.... The only thing left would be the cabs.
But you're right.... we will see. If anything, they will def improve suspension performace being a solid bushing. Prob give a tighter more precise feel.
Old Mar 15, 2013 | 09:57 AM
exactly. my struts are shot, i'm gong with koni yellows for replacing (im on springs) and im also on those endlinks. i could bend the stock ones with my hands!
Old Mar 15, 2013 | 09:58 AM
Staged07SS's Avatar
Administrator
Administrator
Yeah, I felt a slight improvement with the MOOG endlinks.
I like the fact you can grease them
Old Mar 15, 2013 | 10:13 AM
mmhmm. plus i just needed 'em for the lowering springs.
i keep looking at the zzp full control arms... but idk what would make them better than the stock ones, and for 500 bucks idfk...
Old Mar 15, 2013 | 10:14 AM
i haven't heard of too many people using that package... not to say its a bad package though. like some have said if your looking to improve ride quality either replace with stock/moog components, or even downgrade of base model cobalt stuff.
side note, that is a decent deal for a set of coilovers. good for turns and stuff
Old Mar 15, 2013 | 10:21 AM
  #36
Staged07SS's Avatar
Administrator
Administrator
(07MetallicSC) has the koni yellows. They are a great setup, but the fronts need to be modified to work on the Cobalt.
I'm going to get the Koni yellow rears when I get some extra funds.
I like the fact that they are adjustable. Tighten up the rear for less squat on launch.
Old Mar 15, 2013 | 11:13 AM
  #37
^exactly! i'm doing the full set probly when my tax return check arrives... *cough cough*
when it comes to modifying those strut caps, what is it, just drilling them out some so you can reach the adjusters?
i think i'ma keep them all the way soft for daily driving
Old Mar 15, 2013 | 11:19 AM
  #38
Staged07SS's Avatar
Administrator
Administrator
Yeah, something like u use part of your old strut housing.
The instructions are on ZZP's site.
Old Mar 15, 2013 | 11:25 AM
  #39
ah ok thanks i know i've found that before somewhere.
Old Mar 15, 2013 | 12:04 PM
  #40
duffman11's Avatar
I just did a new FE5 on my TC when I did my whole suspension include Swaybar links (MOOG). It made a world of difference. I would say ever 70-80K you should replace your shocks and struts. My springs are sportlines. The ride is fine unless you like to go over speed bumps. The rear has practically no play. It's pretty stiff in the back. That's my 2cents.
Old Mar 16, 2013 | 01:43 AM
  #41
BLue NoTe's Avatar
They are rebound adjustable, bump damping remains the same as stock and isn't adjustable. Besides squat and dive are MAINLY functions of the spring rate, not so much the dampers
Old Mar 17, 2013 | 04:15 PM
  #42
SS89's Avatar
I just ordered a set of SSC springs from ZZP hopefully that doesn't make me want to kill myself lol
Old Mar 17, 2013 | 04:54 PM
  #43
C_A_D88's Avatar
Is there any brand of rear shock that's overall just more stiff/able to limit how far the car drops?
I'm on bags n can't rely on springs
Old Mar 18, 2013 | 07:12 AM
  #44
Staged07SS's Avatar
Administrator
Administrator
Thank you for making that clear.
I'm an engine guru not suspension. Still learning....
Old Mar 18, 2013 | 02:58 PM
  #45
m33pm33p's Avatar
ss s/c is just as easy to drive as my tc was, first can be a biotch but like any car you get used to it. Still takes me a week or so to get used to my car again after driving my winter beater.
Fearedbynone
Apr 14, 2016 03:25 AM
riceburner
Oct 2, 2015 05:47 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Cobalt_Daddy
Sep 27, 2015 06:59 PM
Haily229
Sep 17, 2015 07:18 AM
