Strut help
Old May 15, 2013 | 02:12 PM
Victor Wells's Avatar
Strut help
I bought some Megan racing springs a little while back and just found out I need to switch my struts too and I know nothing about struts can someone help me out on what kind I should get? I have a 08 Lt sedan
Old May 15, 2013 | 02:14 PM
andrewcarr1993's Avatar
The best you can get would be the Koni shocks (tire rack has them cheapest) but you could also just upgrade to LNF shocks (LE5).
Old May 15, 2013 | 02:18 PM
Sox-Fan's Avatar
Got Brakes?
But, he's asking about struts, not shocks.....
Old May 15, 2013 | 02:23 PM
I have no idea what I'm asking about I just have no clue what to do when I put my springs on
Old May 15, 2013 | 02:24 PM
Sox-Fan's Avatar
Got Brakes?
Front, right?
There is a how to around here. I'll find it for you.
Old May 15, 2013 | 02:26 PM
Sox-Fan's Avatar
Got Brakes?
https://www.cobaltss.net/forums/how-...18/#post346764
Step by step
Old May 15, 2013 | 02:27 PM
The front is struts and the back is shocks right?
I'm not asking how to do it I'm just trying to figure out what I need to do it the right way thanks tho
Old May 15, 2013 | 02:30 PM
Sox-Fan's Avatar
Got Brakes?
Correct.
Sorry I use the term interchangeably since they're practically the same thing (let the flame begin)
Old May 15, 2013 | 02:31 PM
Originally Posted by Sox-Fan
Correct.
So do I need just new struts or new struts and new shocks?
Old May 15, 2013 | 02:37 PM
Sox-Fan's Avatar
Got Brakes?
You might not need either. You or your mechanic would have to tell us. I'm not there looking at your car.
You CAN change springs without replacing shocks or struts, if that is what you are asking. You only need to replace them if they are bad. And from my office, I cannot tell you if they are bad, sorry.
Old May 15, 2013 | 02:40 PM
I was told that I need to replace my struts when I change my springs
Old May 15, 2013 | 04:51 PM
Cman46290's Avatar
Unless they are leaking or blown out.... then no... you dont need to change them. Typically putting lowering springs on a factory shock/strut will cause them to go bad faster.... so a lot of people just replace the shocks/struts while they already are doing springs....but you dont HAVE to.
Old May 15, 2013 | 05:32 PM
chevygirl2006's Avatar
5000+ miles on lowering springs with 96k miles on my stock struts and shocks and im still fine lol
Old May 15, 2013 | 05:37 PM
Alright thanks!
Old May 15, 2013 | 08:34 PM
kzak104's Avatar
they are called fe5, if you go somewhere and ask for le5 they will hand you an engine. lol
Old May 16, 2013 | 08:28 AM
SS89's Avatar
You need to use a spring compression tool to compress the spring inside the strut and then unscrew the top plate. You can then remove the old spring, insert the new one and screw back on the top plate. Here's a picture when I did mine.
Old May 16, 2013 | 11:20 AM
Thanks for all the help everyone!
Old May 16, 2013 | 11:26 AM
I'm getting messed up with all the terms. Knew I should have searched it vs just going by memory.
bigdeertz
Nov 17, 2016 09:41 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
ROADKONE
Sep 9, 2015 02:32 PM
