Struts and springs or coilovers
Old Mar 8, 2013 | 06:06 PM
BALT06SS's Avatar
So I just found out I need two new front struts. So I'm going to just replace the front and backs. can't decide if I should get those with lowering springs. Or if I should get coilovers. What do you guys think? And which brand should I go with?
Old Mar 8, 2013 | 06:19 PM
chevygirl2006's Avatar
you only need 2 struts. Not 4.
Old Mar 8, 2013 | 06:24 PM
turbosmart4's Avatar
Tc shocks n struts and yyz suspension for handling. Coilovers for the looooow life
Old Mar 8, 2013 | 06:44 PM
BALT06SS's Avatar
Ya but I don't want two aftermarket ones in the front and two stock ones in the back
Old Mar 8, 2013 | 06:46 PM
Your car only has 2 stuts and 2 shocks. You don't need 4 period lol
Old Mar 8, 2013 | 07:04 PM
BALT06SS's Avatar
Oh alright got ya. Didn't understand at first lol
Old Mar 8, 2013 | 07:12 PM
If you can afford coil overs then get those. Especially if you want a big drop.
Old Mar 8, 2013 | 07:21 PM
BALT06SS's Avatar
Other than the lower drop is there any other advantages to them over just new struts with lowering springs?
Old Mar 8, 2013 | 07:35 PM
No idea. Just that you can adjust them to the way you want.
Old Mar 8, 2013 | 08:04 PM
07cobaltLScoupe's Avatar
for starters you can adjust the height from all the way up to all the way down, which is usually a difference of 3.5"-4". secondly you can adjust the "dampening" which is how the shocks/struts react, you can set that to be from very soft all the way up to very stiff. most coilovers come with camber plates for the front as well which makes it a lot easier to perform an alignment after you do the install. it all depends on what you want to achieve and what you're willing to spend.
Old Mar 8, 2013 | 08:45 PM
BALT06SS's Avatar
Alright thanks for the info. So if you can afford coilovers that's the best way to go?
Old Mar 8, 2013 | 08:52 PM
i'm not going to say a definite yes or no, personally i was on Eibach Pro-Kit springs for like 2.5 years and switched to coilovers last summer to be able to go lower. if you want to go low and have the ability to adjust things a little bit go coilovers, now if you just want to go a little bit lower and handle like a dream i'd say go with FE5 shocks/struts and Powell YYZ springs. it's much easier to decide what you want now and spend money once than change your mind like i did and spend money twice
Old Mar 8, 2013 | 09:04 PM
BALT06SS's Avatar
Alright I will prob just get shocks and struts with some springs. I know this has been discussed before but in your opinion are FE5s better than kyb?
Old Mar 8, 2013 | 09:54 PM
for normal and spirited use the FE5's should be plenty with the right set of springs
bigdeertz
Nov 17, 2016 09:41 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
