Suspension and brake facts (FE1, FE3, FE5, J41, JM4, JL9)
Not entirely correct, what you said above it true though, but the ends of the bars are shaped different so that the endlinks are better aligned creating better steering response as well as creating a smoother more linear weight transfer.
Werd. Oh **** son where'd you learn that?
Ive had both bars, on the street with a mostly LS car you will mnever tell thwe difference in my opinion, its not worth the extra money unless youre building the whole package.
I posted this in the LNF General forum but was asked to repost it here...
FYI: 08-09 SS/TC Rear rotor GM part #
For those that need it and for future searches.
15921402 rear brake rotor 08-09 Cobalt SS/TC
Verified from Gmpartsdirect.com by my VIN Number.
That is all.
That is all.
what a great thread...
ok so let me get this straight
i have an 08 G5GT aka FE3. If i wanted to upgrade to the LNJ LE5 front sway bar all i would need would be the new bushings/Clamps and the bar ccorrect? no need for new endlinks as this should botl right into the FE3. Being that i have an 08 no need to worry about getting one bolt clamps, as i should have 2 bolt.
so part numbers needed to order are the following
2 x Clamps 10389617
1 x sway bar 15821093
2 x bushings 15822993
once again no need or gain for new endlinks correct. i hope i got this right and didnt noob out
2 x Clamps 10389617
2 x Clamps 10389617
2 x Clamps 10389617
You actually should have the same links, and clamps as the FE1 cars. You dont NEED FE5 links buy you should get them, you also wont be able to use those bushings or clamps if youve got a 1 bolt/1 tab clamp like I think you do. Youll need the 2005 SS FE5 bushings.
man and i thought i read this thread correctly
thansk Maven, as always you rock... what would be the benfit of the FE5 endlinks over the FE3 ones i have all ready?
edit
my 08 G5GT is the 2.4 l not the sport version with the 2.2, does this change anything above. i know the coablts got changed as well as the G5's but i got the last year of the 2.4
edit
does it matter what year end links i used as long as they are FE5?
edit
rereading the post it appears all FE5 endlinks are the same
ok last post, just want to make sure i got this all right before i go to the delaer and order parts.
my car is 08 FE3 which uses 1 bolt bushing clamps i
Ineed to order the following
2x Insulators: 22700091 (05 FE5 which work with One bolt clamps)
1x Sway Bar: 15821093 (all years of FE5 use the same Sway bar)
optional but i will get as long as they fit n work
2x Endlinks: 20784688 (all years of the FE5 use the same end links
and i can safely tell the dealer this parts will be direct plug and play with my 08 G5 GT with the FE3 set up
edit
I have a question, im thinking putting the eibach sway bar kit without lowering the car. Is that recommended or do i need to lower the car first? (i like the car that way it is)
also i read (not sure) that if i were to put them i only need to put the rear one.
please any comments, reference or information would be appreciate.
thank you
another question which one is the one for my car? 2007 2.4L
im looking a lot of different parts number from eibach
-899.312 dont know
-899.310 i think is the front only
-899.320 Kit i think
http://www.ottperformance.com/advanc...=15&search.y=7
dont know if this information is correct. please confirm
thank you
thank you
-899.312 dont know
thank you
