T/C Shocks and Struts vs Konis?
Old Dec 29, 2009 | 09:24 AM
BlackLS's Avatar
Ok after doing a bit of searching i haven't found an answer to my question yet so which does everyone think would be the better performance choice for a 2.2 with progress lowering springs. It is not auto crossed just aggresively driven on back roads. Is one really better than the other or not? Also will the T/C Shocks and struts bolt up direct to an Ls or do they need modification to fit?
And finally replacing the shocks and struts with either of these options should not raise or lower the ride height correct?
Old Dec 29, 2009 | 05:48 PM
395 plus's Avatar
Konis are nice but I would personally go with the TC shocks/struts. They bolt up exactly like yours do. The konis are nice but twice the price and I had them on the G5 I had before the Cobalt and I had progress springs the car handled great. Plus adjusting the rear shocks sucks because you have to take the bolt out of the shock to turn it. The fronts I didnt think fit as well as stock built shocks do.
Old Dec 30, 2009 | 12:50 AM
Maven's Avatar
I run the LNF stuff on my car. Koni has high quality stuff but I dont like having to cut apart my struts to install things, and I dont like the way Konis ride.
Old Dec 30, 2009 | 01:17 AM
kissrocker52's Avatar
i am lowering my 2.4 on ksports springs this summer will th tcs work ok for mine its a 2006 and i have been told i should upgrade my struts
Old Dec 30, 2009 | 07:03 AM
BlackLS's Avatar
Could someone give me a direct link to somewhere to buy the T/C shocks and struts cause i've been looking for them but i'm having a hard time finding them.
Old Dec 30, 2009 | 08:58 AM
Stiner's Avatar
go to crateenginedepot they have them or go to a dealer. I just got some not too long ago I'm pairing them with some pedders. There's a guy in my area that goes to the track often and swears by that combo so I'm giving it a try
Old Dec 30, 2009 | 11:39 AM
JoshuaVnyrd1817's Avatar
I'd go with the LNF set up. Heres a link to them if you still need it.
http://www.crateenginedepot.com/stor...sion-C188.aspx
Old Dec 30, 2009 | 02:15 PM
NobDaSkrilla's Avatar
A question that might help us both is do you need anything besides the shocks and struts or can you buy that package and install it with your factory parts the reason p ask is they have a strut bracket for sale do you have to have it?
Old Dec 30, 2009 | 10:44 PM
395 plus's Avatar
No you just need the Shock/struts everything else is the same as what you have already
Old Dec 30, 2009 | 10:49 PM
WVsuperSS's Avatar
I run the Koni's and love em...
Old Dec 31, 2009 | 01:08 AM
so im lowering on k sports when i upgrade my struts do i just need struts or is there other parts that i need
Old Dec 31, 2009 | 08:52 AM
BlackLS's Avatar
So this right here is exactly the ones off the Turbocharged right? http://www.crateenginedepot.com/stor...P2433C188.aspx
And thank you JoshuaVnyrd1817 i saw them on there but i wasn't sure if they were the ones from the T/C or S/C.
Old Dec 31, 2009 | 06:53 PM
tru2nrtt777's Avatar
All you need are the TC front struts and rear shocks. Everything else will bolt right up.
Old Dec 31, 2009 | 07:58 PM
thanks
Old Dec 31, 2009 | 08:01 PM
mkulrey13's Avatar
konis ftw. Ive had mine on SSC springs for 3 years with no issues.
Old Dec 31, 2009 | 08:56 PM
had my konis for 2 years on H&R sport springs and wouldnt change it. and its not hard to adjust the backs. you set them before you put them in. EVEN if you dont like it it takes 10 mins to take out adjust and put in. 10 mins thats it. Konis got my vote
Old Dec 31, 2009 | 10:39 PM
warrenb213's Avatar
as opposed to KYB AGX's which are half the cost, provide the same performance, and are adjustable without removing crap.
till KYB releases AGX's for the Cobalt, SS/TC FE5 FTW.
Old Jan 1, 2010 | 12:45 PM
so why mention them if theyre not even out for the cobalt? fail
Old Jan 5, 2010 | 11:42 PM
2.4SlowassBalt's Avatar
subscribed and thanks for info
bigdeertz
Nov 17, 2016 09:41 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
