Tips for Pedder install
Old Mar 21, 2011 | 04:38 PM
D-mac's Avatar
Read a few comments about one side sitting wrong and such
Who has tips to get these on properly the first time?
Old Mar 21, 2011 | 04:44 PM
Bl4des's Avatar
put the on the ground standing up the spring lean to the front and i cut the bottom rubber piece a little bit to make it easier to get the spring on
Old Mar 21, 2011 | 04:46 PM
68nova200's Avatar
Mine took like two weeks of driving to get the back springs to sit right. Just make sure it is on straight and you will be fine except for the creaks when they settle.
Old Mar 21, 2011 | 04:48 PM
northvibe's Avatar
yes dont install the springs wrong!!! they will lean a way just like Bl4des says. getting the plastic disc thing on the rears is a *****
Old Mar 21, 2011 | 04:49 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Old Mar 21, 2011 | 04:50 PM
68nova200's Avatar
If you have a huge hydraulic press that would probably get them in easy but not many people have access to those.
Old Mar 21, 2011 | 05:13 PM
D-mac's Avatar
I do have access to a 50 ton and 15 ton press
If any of you have pics of any of the issues you are speaking of that would be good
Old Mar 21, 2011 | 11:16 PM
68nova200's Avatar
no pics but the springs are a major pain in the butt to get over the plastic spring seats. I havent tried the press but i think it would work better than pushing on it with your hands.
Old Mar 21, 2011 | 11:18 PM
HB_SS/TC's Avatar
you just need man strength
Old Mar 21, 2011 | 11:21 PM
09sscalicobalt's Avatar
haha yea that i didnt have right david? other than that there just a regular spring
Old Mar 22, 2011 | 12:52 AM
Wangspeed's Avatar
I whittled the plastic parts down a bit with a knife, and then took a kitchen torch to soften them up. They were not going in, even with lube on. In fact, I'm pretty sure it would have cracked. Mine were tight enough to permanently deform the metal ring.
Not sure I'd try this on a press. That will be very dangerous if it slips. Just whittle and torch it.
Old Mar 22, 2011 | 01:21 AM
SSPainter's Avatar
i put them in as far as i could then put them on the car and bounced the trunk and hit the springs with a rubber mallet and they were seated before i took them on the road. ***make sure the rears are leaning forward and the small end is the top.
ls1fbody's Avatar
Haz l33t wheelz.
Originally Posted by blazin07ss
luuuuuuuuuuuuuuuuuuuubbbbbbeeeeeee!!!!!!!!!
Old Mar 22, 2011 | 12:53 PM
Sweetsandman's Avatar
Looks like I'm in for some fun when the weather warms up and I get to install these suckers.
Old Mar 22, 2011 | 10:57 PM
jboogie's Avatar
lube, heat gun and a little pressure on a press worked for me. Disclaimer: this is not smart but worked well. lol
Old Mar 23, 2011 | 12:33 PM
ssyellowss's Avatar
I had to do the same as wangspeed for the rears. I took a dremel with a sanding bit and lightly trimmed the lip on the plastic seats. there was no other possible way they would fit. i need to get back under and check because at initial install time the plastic seat and spring wouldnt seat completely. I was thinking the weight of the car would do it but not even that helped at the time.
Old Mar 23, 2011 | 01:54 PM
xnigelx's Avatar
i used a grinder to grind down the plastic bottom "shoe" a tiny bit to get it to fit properly.. it was still very snug. then we jecked up the torsion beam to get that to snap onto the axel part
Old Mar 26, 2011 | 01:13 AM
toolman's Avatar
When I installed them the first time, I was able to get everything together by hand. However, the foam disc that goes on top of the spring was shot. So, I ordered a new set of them and they came with new bump stops and everything. When I went to swap them out, the new parts were a huge pain to install. I used lube, jumped on them, smacked them with a rubber hammer, the whole nine yards. I ended up using a press, but don't just throw your spring onto the press and start jacking on it.... that will create a very dangerous situation. Take your time to block things up so that you are only compressing the top one or two rings of the spring. They slid on like butter.
The fronts are self-explanatory.
Old Mar 26, 2011 | 03:01 AM
ronn's Avatar
I hope this doesn't sound dumb...but you're supposed to put both end caps (bump stops) on the springs BEFORE you insert em....
like spring on the left
Old Mar 26, 2011 | 07:53 AM
SSPainter's Avatar
or get them close and let the weight of the car do the rest.
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
