Toe Out Toe in rear adjustment
Old Aug 10, 2009 | 10:17 PM
oncefiredbrass.net's Avatar
I need to know if there is a rear toe adjustment or what can i do to adjust this. I have 1/2 degree toe out on the left rear. Its not much but noise in corners driving me nuts. I do not see any kind of adjustment so are there any parts I can buy that will allow me to adjust it. Thanks in advance.
Old Aug 10, 2009 | 11:05 PM
ogc's Avatar
ogc
shims
Old Aug 10, 2009 | 11:08 PM
madmark's Avatar
Originally Posted by ogc
shims
wrong.......
non contact shims lol sorry im jk
Old Aug 10, 2009 | 11:31 PM
shims
Where do I put the shims.
Old Aug 11, 2009 | 12:23 PM
DaBuzzard's Avatar
If you just throw shims at it blindly, you may end up with worse alignment than you have now.
Let your alignment shop worry about that, they need to put it on the rack to get it right anyway.
Old Aug 11, 2009 | 12:53 PM
Area47's Avatar
Rent me! per hour
leave it be
Old Aug 11, 2009 | 06:17 PM
Maven's Avatar
1/2 degree is within spec, listen to Are, leave it be.
Old Aug 11, 2009 | 08:50 PM
Toe
I will leave it alone thanks. I took the car in for an alignment at firestone they said there is no way to adjust it. Thats why I thought someone here would know. If you think its fine I will leave it be. Thanks for the advise.
Old Aug 11, 2009 | 11:43 PM
fjordbosun's Avatar
I lowered my car with Sportlines and the right rear was out of spec. Heard about putting in
a shim somewhere, but no buddy knows where to put it, I think I might know but it won't
fix my alingment problem. It was pulling pretty to the right not bad but was noticable.
After about 3 months now it has mellowed out. I was told that the springs will settle
in but that may be like the shims.
Old Aug 12, 2009 | 09:31 AM
ogc's Avatar
ogc
Your rear alignment was most likely out from the factory, sportlines would not cause your rear alignment to get messed up.
My car has .05 toe out on one wheel in the back and the entire rear end has a thrust angle of like 0.15 or something like that. Its from the factory, and technically its all within spec.
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Delta coupe
Sep 30, 2015 08:11 AM
