Ttr Sway Bar
Old Apr 24, 2008 | 09:03 AM
  #51
wordsthatiwrote's Avatar
well. im at the vet now. my dog has scratched herself raw.its really nasty.
Old Apr 24, 2008 | 09:29 AM
  #52
Sergio's Avatar
Interesting thread...
I'd just like to point out that the SS/SC already has a 22mm rear sway bar that is welded on and sits inside the torsion beam.
Now if we take a look at the LNF cobalt, which has nurburing track record beating suspension, we see that GMPD bumped it up to 24mm.
I'm not going to question whether the design of the TTR bar works or not, but if GMPD only increased the diameter by 2mm with fantastic results, I would be just slightly cautious to adding a whopping 25.7mm on top of the stock 22mm bar.
Old Apr 24, 2008 | 09:53 AM
  #53
i Want to buy a strut bar too
Old Apr 24, 2008 | 09:56 AM
  #54
07LaserBlueSS's Avatar
Check out DC Sports or MRZ the MRZ one is really nice, and you can get a custom design on it.
Took me about 20 - 25 mins to install.
Old Apr 24, 2008 | 10:29 AM
  #55
TurboTechRacing's Avatar
Soon we will have that ready 100% 6061 T6 Aircraft Grade aluminum, 1 welded unit, does not "bolt together" like other aluminum strut bars which are not 100% rigid.
Old Apr 24, 2008 | 11:47 AM
  #56
SOLD, let me know when they come out. Ill buy first.
Old Apr 24, 2008 | 11:50 AM
  #57
Sergio's Avatar
Originally Posted by 07LaserBlueSS
If you are an auto crosser, you would understand the benefits the sway bar gives.
Thanks for the arrogant reply. What exactly are you trying to achieve with your suspension that calls for such a stiff rear end? I happen to know that this car's handling is quite balanced and you can dial in understeer and oversteer properties just by adjusting tire pressure. I can have the rear end coming out under no throttle and then have it track beautifully around a turn under throttle - all with the stock suspension.
Do you even know what would happen if you had to make a turn in an emergency braking situation? The rear end starts to come loose with the stock sway bar already!
And you call yourself an autocrosser. With the mods you have/planning to do, you would be competing in a class that would put you against much bigger fish. Have fun!
Old Apr 24, 2008 | 12:09 PM
  #58
Mods should delete these posts of all this bickerring.
EDIT: Your motor is clean. mine is dirty and i have oil seeping from the valve cover a little.
Old Apr 24, 2008 | 12:10 PM
  #59
I will delete all my posts, just defending my position.
haha those pictures were taken a while ago lol
Last edited by 07LaserBlueSS; Apr 24, 2008 at 12:10 PM. Reason: Automerged Doublepost
Old Apr 24, 2008 | 01:13 PM
  #60
IonNinja's Avatar
Originally Posted by thekingsSS
I experienced a sway bar first hand for about 7 months, and experienced 0 (zero) difference in handling when I took it off.
Sway bars in general are not worthless, on this car they dont do much.
you may get different results from the FE5 suspension but in MY car it felt alot less sloppy on the very first turn I took and it wasn't even at high speed.
Old Apr 24, 2008 | 01:15 PM
  #61
Fresh's Avatar
Originally Posted by XM15
Ummm, you had other people tell you it was doing nothing? Couldn't you tell for yourself?
I felt a big difference when I installed my Progress rear sway bar.
diddo
Old Apr 24, 2008 | 01:30 PM
  #62
thekingsSS's Avatar
I agree, and the only reason I brought anything up was because this was originally posted in the 2.4. I cant say that I can speak for everyone, I can only speak for me. Thats all I was trying to do in this entire thread, give people my opinion from my experiences.
I just remember reading so many positive reviews about the progress bar so I bought it. I feel like I wasted money on it cause I never noticed a difference in handling, not even a little bit. So I figured I would give that opinion to others on the board, cause thats what a forum is all about.
And TTR, Im sorry I claimed to have your sway bar. I bought it so long ago and I saw the picture of yours and it looked identical to mine so I assumed it was the one I bought.
Old Apr 24, 2008 | 02:58 PM
  #63
I dont disagree with that at all. I run a 2.4. I just hate reading all this stuff where people flame others for their opinions. But you may want to state in the beginning of your post that it is your OPINION and thats what it is. Cause it really did seem like you were stating a fact.
No need for bashing, just friendly sharing of information. It not like we are actually viing for anymoney or pinks. why fight. share grow and learn.
EDIT: Is there such a bar in the front of the vehicle that can be replaced with a stiffer one? Stabilization bar i think its called. See, Id love to tighten up my suspension. Dont exactly have the money nor the driveway clearance to lower my vehicle. xD its like a foot drop off my drive.
Old Apr 24, 2008 | 07:17 PM
  #64
YSUsteven's Avatar
Then if you really don't want the sway bar, and its still in good shape with all the hardware, post it in the classified section for $50 + S&H and I am sure that someone would buy it.
In order to notice you have to know what you are looking for. I didn't buy the bar because I wanted less body roll. I bought it because I wanted the car to be "looser" through turns. The bar did help a little, which is all I really wanted anyway. Usually cars are designed to "push" in turns so that there is no chance of the back coming around. Also because our cars are front heavy, they "push" even more.
Even though GM calls it a stabilizer bar, its really a sway bar.
If you are stock, you could upgrade to the FE5 front sway bar, it is just a little thicker than the one on your car. You can pick one up from CED. Installation can be difficult, I believe that you have to drop the engine cradle to get to and replace the bar.
Old Apr 24, 2008 | 09:28 PM
  #65
Hmm, Ill have to look underneath to see.
Old Apr 25, 2008 | 03:07 AM
  #66
FastPace Motorsports's Avatar
Wow, you can make a 1 weld unit to clear all of the crap in the engine bay. I have to see this before believing this.
Old Apr 25, 2008 | 07:37 AM
  #67
It is even a "Double Bar" design, like you see sometimes DC Sports offers, but all aluminum.
Old Apr 27, 2008 | 08:17 PM
  #68
gRuNg3b0y's Avatar
well I guess I'll wait for that one to come out!!
Old Apr 28, 2008 | 09:17 AM
  #69
Hopefully soon, now that the sway bar is shipping...
Old Apr 28, 2008 | 05:07 PM
  #70
Whats soon? This summer
Old Apr 28, 2008 | 05:26 PM
  #71
Yes by then testing them now....
Old Apr 28, 2008 | 06:00 PM
  #72
gRuNg3b0y's Avatar
I'm definitely going to be on the list when this one comes out!!
Old Apr 28, 2008 | 07:57 PM
  #73
INFE's Avatar
yea i will probley be on that list as well. BTW anyone that says that TTRs rear sway bar does not do anything is stupid! It works great!
Old Apr 28, 2008 | 08:21 PM
  #74
do you have any audio of your corsa exhaust? Im thinking about getting one of them if i can scrape up enough money to do it.
Old Apr 28, 2008 | 09:35 PM
  #75
INFE's Avatar
the thing about the corsa is it sounds pretty good when its hot, but went u first start up the car it sounds terrible. Also its very very very loud. With the vibrant/ corsa set up i have you can hear me for miles away.
