Vibrations After Stb Install!!!
Old Feb 16, 2007 | 12:37 AM
chipmonk212121's Avatar
Ok, so i installed my strut tower brace in the parking lot after work. everything is tightened. and now all of a sudden my car is vibrating at 100mph. i havent gone over 75 in over a week so i dont know for sure that the STB caused the problem but what else could it be???? it wasnt doing this before
Old Feb 16, 2007 | 12:45 AM
c0ld29's Avatar
it's possible... I say to make sure uninstall it and find out
Old Feb 16, 2007 | 12:52 AM
stotte20's Avatar
yea i wouldent want no viberatons of ne sort at over 100
Old Feb 16, 2007 | 12:53 AM
boostbalt's Avatar
When you installed the brace was the car on a level and flat surface? Also did you torque it to the specs using the same tightening pattern as you would lug nuts?
I am running the DC Sports STB and I have had no problems at all, I torqued it to spec on a level concrete slab to make sure that it wasn't putting load on a single strut. Be careful if you ever jack the car up with the brace btw, I'd remove it first..
Ryan
Old Feb 16, 2007 | 12:56 AM
stotte20's Avatar
what would happen if you jack it up with the brace?? thorow a strut off or somting??
Old Feb 16, 2007 | 12:58 AM
there is only 2 bolts on each side..... and there are no instructions that come with the brace....... it was done on a level surface
Old Feb 16, 2007 | 01:03 AM
stotte20's Avatar
thats weird? did you check your tires and all make sure they were inflated good. might just be that you feal more with these like you would a motormount
Old Feb 16, 2007 | 04:16 PM
IonNinja's Avatar
uninstall it, then jack the car up so there is no weight on the front wheels and then re-install and test for vibrations.
Old Feb 16, 2007 | 09:38 PM
boostbalt's Avatar
Ya know... I wonder if this is something else completely.. I saw an exact thread on thisbefore... Hmm I know I've seen this problem on here before but I can't seem to find it.. I don't think its the STB
Old Feb 16, 2007 | 11:22 PM
anyone else have an insight on it? i think i will have access to a lift tomorrow. i will uninstall it and reinstall it tomorrow.
Old Feb 16, 2007 | 11:58 PM
torrin1234's Avatar
Man, I think theyre supposed to give off some vibrations, but I wouldn't know, I got mine after I had my motor mount and torque dampner installed.
Shimmy shimmy!
Old Feb 17, 2007 | 12:56 AM
The01Cav's Avatar
make sure that the wheels and tires are balanced fine as well.
Old Feb 17, 2007 | 03:56 PM
took it off. jacked teh car up to change oil. put back on. fine now.
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Tupp
Sep 30, 2015 08:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
