your thoughts on cobalts allumium front suspension
Old Sep 10, 2006 | 05:11 PM
quad4racer's Avatar
Hey guys im buliding an ecotec powered jbody for track use. anyways i went to look at a cobalt and noticed that some of the front suspension components are allumium. For example the steering knuckles/spindle assembly looks like its allumium. I wonder if thats why the gm requires kunckles to be upgraded when doing autocross. I also noticed that the front knucles cant take to much stress as seen on several accident photos. On the older jbody the knucles and all suspension compontes were all steel/iron. what are your thoughts on this which would you say is stronger? Duscuss.
Old Sep 10, 2006 | 05:24 PM
Sicklyscott's Avatar
I'd say that steel is definately stronger but the unsprung weight is where the advantage is. The Cobalt should feel a bit nimbler while cornering and auto-xing...which is kind of ironic since it fails auto-xing
Old Sep 10, 2006 | 05:28 PM
Cobalt_Supercharged's Avatar
I think it would depend on what kinda track use you are talking about. Straight line wouldn't make a big difference, but road courses and AutoX would bennefit from the light weight of the knuckles and control arms.
AutoX is made up of hard, sharp turns which could be the cause of the problems with them.
Old Sep 10, 2006 | 05:34 PM
StinkBOMB's Avatar
Confused. Would it benefit at an AutoX or cause problems?
Old Sep 10, 2006 | 07:08 PM
quad4racer's Avatar
its going to be a drag setup were going to gut the interior so its not going to be streetable. I mean i see the benifits fo allumium i just personally would not feel safe as a track car. I wonder if gm uses the stock kuncle assembly for their drag program.
Old Sep 10, 2006 | 07:16 PM
It is bennificial because of the weight reduction, but the stock design is weak so it causes problems.
joeworkstoohard's Avatar
https://www.cobaltss.net/forums//showthread.php?t=19407
tada
Old Sep 10, 2006 | 07:34 PM
StinkBOMB's Avatar
Originally Posted by joeworkstoohard
So what I got from that thread was don't replace the knuckles unless you plan on AutoXing.....kind of. They never answered if you could align to stock specs and use the stronger knuckles.
Old Sep 10, 2006 | 07:40 PM
Asphalt Assault's Avatar
The arm strength is not a problem. these arms are plenty stront. the weakness that is felt in these cars are the control arm bushings. I am working with others to resolve the problem through after market or designing our own.
Old Sep 10, 2006 | 09:38 PM
JonyyB's Avatar
Site Founder
moved from 2.0 tech to Suspension.... please post in the correct section
Old Sep 10, 2006 | 09:43 PM
J-Body Performancealready makes poly control arm bushings, but that does change that the steering knucles break under the strains of auto-x.
Old Sep 10, 2006 | 11:29 PM
Doc's Avatar
Doc
wonder if this will help
Powell Modified Cobalt Control Arms
The Powell modified control arms reduce camber and toe change deflection under hard braking and cornering, and improve straight line cross wind stability; there is a side effect of reduction in power hop on launch. There is a small increase in ride harness, but a reduction in braking "clunk", caused as the control arm deflects and hits the cross member, when making hard stops.
Modified control arms use spherical joints and Delrin inserts. All Powell installed control arms receive a ball joint protective heat shield. Please note that the outer ball joint is not serviced separately by GM and complete control arms have to be purchased if the ball joints are no good.. Customers that send in arms for modification have to be sure that the ball joints are in good condition.
The installation is simple, the parts and work are not; complete Cobalt modified lower control arms cost $1075.00 for the pair, deduct $400.00 if you supply the control arms.
Old Sep 10, 2006 | 11:40 PM
Good find Doc.
Old Sep 15, 2006 | 04:54 AM
Badmunky's Avatar
Ummm ^ thats crazzy expensive for some new bushings and a heat sheald!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I have the JBP bushings on my car and I love them.
I also have the Intense trans mounts and ZZP motor mount and I have almost no wheel hop on the track and none on the street at all!
i think that the front suspenson was well made and only needs a bit of tunning to get it to work perfectly for track use.
And I have seen a j-body control arm brake from traction. There stamped steel and welded. If the welds go or the steel streses to much there gone.
There the week point in the j-bodys.
The steering knuckle is the week pint on the delta cars.
All cars have a week point. There will always be a part that will fail befor another. AS soon as you fix that part then something els will brake. Thats just how it is.
Later
Meadowvalien
Aug 17, 2017 06:32 PM
chefhhr
Oct 26, 2015 10:36 PM
Haily229
Sep 17, 2015 07:18 AM
Albertsstc09
Sep 16, 2015 08:18 AM
bobbob160
Sep 15, 2015 11:31 PM
