ZZP Big Brake kit issues?
was going to just do pads and rotors but decided screw it ill just pick up zzps kit
got one side off, bolted the bracket on as per instructions, went to go put the rotor on and the rotor hits the balljoint and bracket, also cant get the caliper between the bracket and rotor
so im not sure if i got sent the wrong rotor or whats going on, or if im just missing something and am retarded
No bueno. Neither are those Chinese drilled rotors. I just picked up a set of Made in good old Germany stock lnf rotors. Stock brakes are more than enough on our cars. Even if you have many horses and drive like Andretti like me
Sucks though. Hope you get it taken care of!
I do track days on a regular basis. Those drilled rotors would crack under heavy track use in no time. Heck I recently cracked a solid R1Concepts rotor lol.
My advice to you would be to return everything to ZZP for a full refund. If they will give you that. And get stock rotors and some good race pads.
considering the pice of the kit im not surprised, nore does it bother me, i just painted the canter hat so they dont rust, as long as they dont crack anyways
Dustin24
Oct 8, 2015 09:15 AM
