data logging selectable tune?
Old Sep 11, 2011 | 02:51 AM
JAYNO20's Avatar
I have a selectable tune from Trifecta, problem is I was data logging the GMS1 tune instead of the actual 23psi Trifecta tune, is that an issue or are they both adjusted together? Should I re-data log the 23psi tune?
Old Sep 11, 2011 | 10:06 AM
dayhoff35's Avatar
Why would you need to log gms1 you'll have to redo it
Old Sep 11, 2011 | 05:00 PM
JAYNO20's Avatar
Didn't know I was logging GMS1. So the 2 tunes aren't perfected together?
Old Sep 11, 2011 | 08:26 PM
dayhoff35's Avatar
what do you mean? the one is gms1 the other is custom, you will need to log the custom one.
Old Sep 11, 2011 | 08:36 PM
RiceCop's Avatar
you can log both and just send both logs to vince. The most important part is the high boost tune, but I usually log both, along with some part throttle driving/cruising. Just to make sure there are no bucking or jerking issues at low speed.
Old Sep 11, 2011 | 08:46 PM
TommyP's Avatar
AWD > FWD
Data logging the GMS1 tune will do nothing for you if you wanna keep it GMS1. That's the purpose is that it looks like a factory tune. You need to datalog the custom tune. the 2 tunes are completely separate.
Old Sep 11, 2011 | 09:52 PM
JAYNO20's Avatar
I had him set the tune to the cruise control switch, and found out later it wasn't on the switch but it was on the traction control button....
Anywho, I just sent a datalog in to him tonight of the 23psi tune so I guess I'll start working on getting that right.
Old Sep 12, 2011 | 10:34 AM
RiceCop's Avatar
He can change it to the cruise switch, just ask
Old Sep 12, 2011 | 12:01 PM
JAYNO20's Avatar
I know, he is doing it now.
Supercharged06SS
Dec 11, 2022 04:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
