data logging selectable tune?
I have a selectable tune from Trifecta, problem is I was data logging the GMS1 tune instead of the actual 23psi Trifecta tune, is that an issue or are they both adjusted together? Should I re-data log the 23psi tune?
you can log both and just send both logs to vince. The most important part is the high boost tune, but I usually log both, along with some part throttle driving/cruising. Just to make sure there are no bucking or jerking issues at low speed.
Data logging the GMS1 tune will do nothing for you if you wanna keep it GMS1. That's the purpose is that it looks like a factory tune. You need to datalog the custom tune. the 2 tunes are completely separate.
I had him set the tune to the cruise control switch, and found out later it wasn't on the switch but it was on the traction control button....
Anywho, I just sent a datalog in to him tonight of the 23psi tune so I guess I'll start working on getting that right.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
