i think i need a tune
Old Jun 20, 2011 | 12:39 PM
sexy_ss's Avatar
i ran my car at the track the other day, granted the track wasnt the greatest, but i ran a 14.7 with a 2.2 60ft and trapped at 94mph....i have a 06 cobalt ss/sc with zzp intake and full exhaust. aeroforce reads 0 degrees of knock. my car runs rich i think because when i clean my exhaust tip and drive it hard, the next day its all black, the car has a factory tune too. what do u guys think?
Old Jun 20, 2011 | 12:41 PM
BlueTurbo's Avatar
That really isn't all that bad. Do you have anything to read fuel trim?
Old Jun 20, 2011 | 12:43 PM
BYT*SS*TURBO's Avatar
He has a Interceptor it says in his post
Set it to O2 mv and tell us what that says when WOT. Im sure its way rich tho.
Old Jun 20, 2011 | 12:59 PM
Iam Broke's Avatar
What target mv do you hope to see on a narrowband, Nick?
Old Jun 20, 2011 | 01:07 PM
blake05SS's Avatar
intercooler pump....
Old Jun 20, 2011 | 01:17 PM
over 900, Im sure it will be richer then that but its always good to make sure it is going rich. Ive seen a couple cars that came and were lean on factory tunes. Not sure if it was a certain intake or what.
Old Jun 20, 2011 | 01:27 PM
Iam Broke's Avatar
I found a table, that's why I was wondering. It shows .875 for NA and .900 mv for blown. Sorry for the threadjack.
Old Jun 20, 2011 | 01:37 PM
IIRC:
(O2 mv/1000)+10=AFR
Old Jun 21, 2011 | 01:11 AM
sexy_ss's Avatar
what should the fuel trims be reading?
Old Jun 21, 2011 | 01:36 AM
87gn06gto07irl's Avatar
Zero ideally. 0- -2 are good numbers.
Old Jun 21, 2011 | 07:32 AM
Staged07SS's Avatar
Administrator
Administrator
This needs to be clarified a little....
At WOT you want your long term fuel trims to be as close to zero as possible. While you are crusing you will see some fluctuation in the long term trims (more with short term trims). Many things can affect your fuel trims on a day to day basis so don't get too crazy over small changes.
Old Jun 21, 2011 | 10:19 AM
SCcobaltSS's Avatar
Your long trims and short trims are going to 0 out when in WOT since it goes into open loop... So they could be 0'd out and you still could be running rich/lean... WB gauge is the only way to see how your car is fueling.
Old Jun 21, 2011 | 10:23 AM
Staged07SS's Avatar
Administrator
Administrator
Long terms do not zero out at WOT (unless tuned that precisely). Your short term trims will/should always though. The short term are the trims affected by open loop.
My long term fuel trims are usually +/- 1.5 at WOT.
Old Jun 21, 2011 | 10:29 AM
Yea, they don't 0 but they stay pretty minimal.
You're just looking to see they aren't 15-20% mainly, obviously it won't be dead on like it should without a tune.
Old Jun 21, 2011 | 10:30 AM
Staged07SS's Avatar
Administrator
Administrator
This.
If they peg 15-20% +/- they will set a rich/lean code (usually).
Old Jun 21, 2011 | 10:56 AM
SCcobaltSS's Avatar
Hmmm.. No matter if I just started a tune or finished the LTFT's near 0 part throttle or WOT. I dont think I have even seen it over 1%...
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
