idle mixture
Rent me! per hour
idle mixture
i noticed something today. sitting at idle. the a/f ratio swings wildly from 14.9 to 14.0
cool, no biggie. look down at the box 2 mins later, it's sitting at 12.2-11.9. what the hell!?!?!
at first start up with my car sometimes it goes as high as 15s on rare occasions it hits16s and starts to kinda bog, then drops to 14.7 and from there its fine, still not sure how to get it steady.
listening..
listening..
HEY MY AEM WB Is bouncing from 16.5 to 14.9 at idle. I don't know if I have an exhuast leak were my dp and manifold connect but I wouldn't think it would read like this. And when I had it in the bung behind the CAT it stayed steady at 14.7 to 14.9.
Rent me! per hour
before the cat it is going to bounce around.
mine is bouncing a lot more in the wrong direction
Rent me! per hour
not from 14.9 to 12.4.
to people who know cobalts, is idle mixture done through ve, or a hidden table somewhere?
for some odd reason im thinking it's done in the VE side of things.
We don't have access to idle airflow tables. Your problem sounds more like incorrect minimum pulse width settings though. Try different numbers in there near the 1ms range and see what happens. I think the correct numbers are on the hptuners forum somewhere.
Rent me! per hour
min PW is set at 0.094
stock gm stage 2 stuff
Rent me! per hour
i know ive woken a old thread i just got my wideband in and at idle ill see 14.5-16.0 . Same during just "normal" driveing but the second i press the pedal it goess 11.5 - 10.9.
and mine is before the cat i got the ZZP 2.5 with the extra bung
now that i got the wideband i tune a little safer
