Knock on cyl 1
Old Jul 5, 2015 | 04:05 PM
murlin15's Avatar
Knock on cyl 1
I only get knock on cyl 1 its only at part throttle and like 2-3 degrees in first and second gear
Old Jul 5, 2015 | 05:08 PM
Sl0wbaltSS's Avatar
stock tune? Normal.
Old Jul 5, 2015 | 07:46 PM
murlin15's Avatar
No a tune for E47 but it is normal?
Old Jul 5, 2015 | 08:38 PM
Knock is never normal
Old Jul 5, 2015 | 09:10 PM
nathan112i's Avatar
knock at WOT is never normal, small amount of knock at partial throttle/false knock can be quite common.
Old Jul 5, 2015 | 09:23 PM
Yeah but he made another thread and it started to happen after he went redline on a pull
Old Jul 5, 2015 | 10:09 PM
If there is something wrong with the tune there will be knock at light load. Had the same issue with my LNF I thought it was normal, my air flow wasn't being metered correctly causing knock from the ECU. Something isnt right, take a log and send it to your tuner to get an update
Old Jul 6, 2015 | 01:03 AM
murlin15's Avatar
I had part of my intake slip off but still slight knock partial throttle and turbo still makes the weird sound like in my other post.
Old Jul 7, 2015 | 02:34 PM
murlin15's Avatar
Cyl1 only in first and second gear
Old Jul 7, 2015 | 02:43 PM
Change the graph to max, and subtract that from your timing tables, if the knock goes away its because of timing. If it's still there, the issue is most likely fuel or air related
Old Jul 7, 2015 | 02:52 PM
JapEatr's Avatar
South Central *********
this^
Old Jul 7, 2015 | 02:56 PM
murlin15's Avatar
Already did that when I saw it but I was just concerned because I noticed it when my turbo started doing making this sound https://www.youtube.com/watch?v=XXDfYpd9NGQ but I think I uploaded a old tune and that's why
Old Jul 7, 2015 | 03:04 PM
knock isn't going to effect your tubro. Does it still knock on cylinder 1?
Get a leak down test and check the turbo for shaft play
Old Jul 7, 2015 | 03:13 PM
Area47's Avatar
Rent me! per hour
knock is the first resort of the ecm to default too. you're not detonating. you have other issues going on.
Old Jul 11, 2015 | 08:39 PM
murlin15's Avatar
It has excessive blow by and low oil blown ringland??
Old Jul 11, 2015 | 08:51 PM
Do a leak down test to find out, but I doubt it since it knocked after pulling the 3 degrees or whatever your max was from the timing tables. Honestly you need to get your tune file looked at, as Area47 said ecu defaults to knock when something isn't correct.
Old Jul 11, 2015 | 10:00 PM
murlin15's Avatar
I cleaned out the oil in the intake and it doesnt sound like zoidberg any more and my oil could of been off due to being jacked up.
Turbo Johnny
Feb 21, 2019 09:41 AM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
Sep 30, 2015 08:18 PM
OrngBalt
Sep 16, 2015 07:45 PM
twilson380
Sep 14, 2015 10:52 AM
