Maf Scaling
Old Mar 16, 2008 | 07:03 PM
memphisr24's Avatar
Maf Scaling
Would upping the IFR by a % allow you to run less g/sec on the maf? If not, what will do that?
Old Mar 17, 2008 | 12:34 PM
Bika's Avatar
Fail Less.
no. it will just screw your AFR.
Old Mar 17, 2008 | 03:08 PM
memphisr24's Avatar
How so? I found a post on hptuners website with a guy claiming raising the IFR is the simplest way to lower the maf. Why would it screw up the afr's? I mean obviously if I just touched the IFR and nothing else, then it would. But can't you compensate by tuning maf and ve?
Old Mar 17, 2008 | 06:17 PM
Bika's Avatar
Fail Less.
yes, effing with the maf table will lower the signal output, but i dont know what effect that will have on your IFR. i always assumed that was strictly dependent on the injectors. why do you want to lower your maf g/cyl? are you moving so much air that you have outrun the tables in HPTuners?
Old Mar 17, 2008 | 06:34 PM
memphisr24's Avatar
Not yet...but if/when I do, I want to know how to get around it...i'm just going to search on hptuners forum.
Old Mar 17, 2008 | 07:36 PM
Josh@ottp's Avatar
if you half the ifr table you can also half the maf table which doubles the grams per second limit in the pcm
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
dennis69
Sep 22, 2015 08:56 AM
dennis69
Sep 21, 2015 11:55 AM
