MAF tuning
Old Mar 25, 2008 | 03:15 PM
  #226
Kaisoboy's Avatar
Now with all the MAF stuff out of the way I do have one question I did ask previously but did not get a clear answer on is this:
When tuning VE in PE above 3 psi I can set a similar filter VE>3psi boost. Is this correct and from there what cell count do I instruct the histo to hit for maximum data?
cheers
Old Mar 25, 2008 | 03:21 PM
  #227
Pickles's Avatar
cheers
Just screw the ve and make it ***** now.
Old Mar 25, 2008 | 03:23 PM
  #228
Kaisoboy's Avatar
I'm just curious.
Old Mar 25, 2008 | 03:24 PM
  #229
06black's Avatar
+1 spell your name in it!
Old Mar 25, 2008 | 03:40 PM
  #230
Kaisoboy's Avatar
That's IT!!!! **** it...(o)(o)... it is.
Old Mar 25, 2008 | 03:51 PM
  #231
06black's Avatar
good man!!
Old Mar 25, 2008 | 03:55 PM
  #232
Area47's Avatar
Rent me! per hour
wheeeeeeeeeeeeeee
bewbies
set the cell count no lower than 20
Old Mar 25, 2008 | 04:20 PM
  #233
Kaisoboy's Avatar
Originally Posted by Area47
wheeeeeeeeeeeeeee
bewbies
For VE-PE tuning? It seemed like I was not getting any hits at all doing WOT runs in VE above PE.All this VE-PE talk is giving me a headache.
Old Mar 25, 2008 | 10:09 PM
  #234
SJSchafer's Avatar
Personally, I do not bother with filters in PE. I get the car up to temp and find a place where I can slow down and do a good 3rd gear pull. I roll into the throttle and run untill RL. Then, just before the rev limiter, I push in the clutch, let off the gas and pop it in 5th. Get back on the freeway and let me SC cool down untill my IAT2s look good, then I do it again. When reviewing the logs, I ignore the lean spikes that sometimes happen for just a sec after PE kicks in. After I think I have it pretty good, I'll do some 2nd gear pulls to check and make sure it all looks good. Sometimes I get stupid with 4th gear pulls, but that gets you in trouble on the street.
Also, I like my PE MAF to err on the side of -2 or -3, because a lot of my real pulls are not in ideal conditions and I may be sitting for a bit. We go lean when we heat soak, so if I am set a little rich to begin with, I hit a 11.7 or so heat soaked, and I'm cool with that.
And NEO, we all know you're an *******, so don't trip...
Oops almost forgot the smiley.
Old Mar 26, 2008 | 01:17 AM
  #235
Kaisoboy's Avatar
So are you talking about VE or MAF tuning or both? Like i said I was having problems getting any data in PE because of the 20 cell count. So if I understand correctly you do 3rd gear pulls to 7000 rpm then shift into 5th and come back down to say 4000 rpm drive until my AIT2s come back down to normal, shift into 3rd again do another 3rd gear pull and keep doing this until you get data. Stop edit the MAF or VE table depending on which you are tuning and go at it again.
cheers
Old Mar 26, 2008 | 01:35 AM
  #236
SJSchafer's Avatar
[QUOTE=Kaisoboy;2120907]
cheers
I'm talking MAF. I sent my post count to 0 and just watch the data. Do a pull, then drive around for a bit to cool things down and do another pull. I do my PE by hand, I don't copy/paste error percent, I study the data and adjust appropriately.
Oh, and your doing 4000 rpms in 5th, you're going too fast.
Old Mar 26, 2008 | 02:29 AM
  #237
Kaisoboy's Avatar
[QUOTE=SJSchafer;2121032]
No No. but I get your point. Thanks
Old Mar 28, 2008 | 12:10 PM
  #238
crt013189's Avatar
i have a quick question im trying to subtract my High Octane table in cells .56 and down to 1.36 by 3* is there any easy way to do this because every time I try i highlight the cells that i want to decrease then do a paste special and subtract but when i do that only the 1st cell changes so what im asking is. Is there a way to decrease all the cells i have selected by 3 or do i have to change each cell manually thanks
Old Mar 28, 2008 | 12:24 PM
  #239
Pickles's Avatar
You should be able to highlight all the cells you want changed, and on the top bar, enter -3 and then click the add button. This will add negative three (subtract 3) from all cells that are highlighted. If you find that only the first cell gets changed, I imagine you may be doing something wrong.
Old Mar 28, 2008 | 12:52 PM
  #240
crt013189's Avatar
thanks i was trying to just subract a positive 3 instead of add a negative 3 that worked thanks
Old Mar 28, 2008 | 02:18 PM
  #241
Kaisoboy's Avatar
Mark, your so smart...haha
See yah folks tomorrow.
Old Mar 28, 2008 | 02:19 PM
  #242
Area47's Avatar
Rent me! per hour
don't divide by zero
Old Mar 28, 2008 | 02:25 PM
  #243
Pickles's Avatar
No. Just multiply by an Imaginary number.
Old Mar 28, 2008 | 02:31 PM
  #244
SJSchafer's Avatar
This thread kills me.
Old Apr 21, 2008 | 06:36 PM
  #245
SSSexy's Avatar
Ok So I am starting down this crazy road in baby steps I have installed 60's and I used the first numbers that are posted in the sticky. First since those numbers were for 60 and since most injectors do not run at 60 exactly is that going to ba a problem? Could you just bump up the multiplier from 1.19 to 1.29? Second should I tune the MAF first liek you say here or tune the VE like it says on the sticky? Third I followed what the sticky said about dissabling dfco but it still seemed like it was still on. Is this just because I am not tuned and its going lean on its own? Fourth when tuning the MAF should DFCO and anything else be turned off?
Old Jul 29, 2012 | 01:41 PM
  #246
Dart_SI's Avatar
bump. very good read for some of you even though this is an old thread.
wish these guys were still on here
Old Jul 30, 2012 | 09:27 PM
  #247
noorj's Avatar
Wow yeah thanks dart, read that at work today great injector info despite it's name haha
Old Jul 30, 2012 | 11:56 PM
  #248
SJSchafer's Avatar
I'm still here. Haven't tuned in forever though. Not sure if I even remember how to.
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
