MAF tuning
So how do you go about doing your timing to the High / Low tables after tuning the fuel, VE and MAF? Can anyone enlighten me on the steps required to tune and add timing for more HP.
Hmmm...It would seem that I have re kindled this thread. haha
thanks
thanks
I swear I need to fly you out here to figure my car out timing wise. At least fuel has some method of math and science and physics and ****. Timing is like some weird magic or something.
steve, it's hard as **** to tune timing when someone is 1300 miles away. im all up for a vacation!
anyways
kaiso, start small. take the timing map {high octane} everything above .55 g-cyl, drop 2-3 degree's as a base to work with. simpley put. from .55 down to 1.36 drop 3 degree's. load map. log. start with a base timing of 14 degree's and work up from there. adding .5 degree's at a time. untill it knocks. then back it off 1 degree. go beat the crap out of the car for a while, still logging of course. look at iat2 temps vs timing. the richer you run, the more timing you can run. to a degree.
this is not an end all be all how to on timing. every car is different, and requires different styles of tuning.
hehehehee
anyways
anyways
Hi Area
Just a recap to make sure I understand.
1. Creat a histo showing IAT2 Temps vs Timing Advance so you can log where the car is running rich so you can see where you might possibly want to add timing.
2. Take the HO table reduce any cells above .55 - 1.36 g/cyl by 2-3*.
3. Add 14* of timing across the board to start with and work up from there adding .5* of timing each time untill it knocks then back it off by 1* in that cell then smooth.
Is my understanding correct
Thanks
don't add 14 degree's. bad bad bad idea. your total timing should be 14.
also. etc adder below 230 degree's zero it out
afr adder. zero it
iat adder. zero this below 140 degree's.
afr adder. zero it
He means your max timing for a run with be 14 segrees to start, if you don't get KR then add .5 degree at a time in the WOT timing places. You can make a filter in the histo of timing advance to filter out any part throttle stuff for WOT timing if you don't know where the WOT timing runs.
sorry but I guess I am just not grasping this.
The higher g/cyl will be WOT. But it all depends on the car, you need to log and figure out where your car runs at WOT. The put the filter to show you timing in the Timing Advance table. Then look at the table and you'll see the pattern. Your filter will be ECT Position say above 95%
And you don't want all of the WOT timing to be 14 degrees or you will most likely have KR. The higher RPMs you can ramp up to 14 degrees and then go from there.
Last edited by BlackSS/SC; Mar 14, 2008 at 12:54 PM. Reason: Automerged Doublepost
OK thanks.
So once I find my WOT range, Is that where you are telling me to increase the timing by 14* then do a log run at WOT and any knock I find reduce it, smooth it and increase any other cells in the WOT range with no knock by a .5* advance and log again, find any knock if any do the same then log again.
OK thanks.
OK, OK I think I have it...Lets Recap.
1. In the stock stage 2 HO table reduce all the cells from .56 to 1.36 by 2 to 3* across the board and this will be my base to start with.
2. Flash the new table and go logging at WOT to find out where my WOT range is and patern. (Which table do I need)
3. Now keeping in mind that I do not want to go Higher than 14* of knock in those cells go out and do another WOT run and monitor any knock over 14* at WOT and reduce those cells then smooth. (which table do I need)
4. Now after correcting the last run add .5* timing to the remaining cells that did not show knock in my original log. Correct those and repeat.
5. So with the 42lb injectors, what would be the most on average timing I would want to add to keep the tune safe.
6. In my histogram which of the tables do I need to have or set up for this.
Thanks alot guys you've been a great help.
