Trading in e85 lsj tune help.
Okay I'm getting a truck. Right now I have 80# injectors with E85 tune. I don't have the time to take it all apart I want it gone now. Will a 60# tune work with 80#s on gas?
hes not swaping 80's for 60's hes taking the 60 tune if he swapped everything over and putting it with his 80's which is a no-no. OP you need to get it tuned correctly or whoever you are trading the car to will be definitely calling you.
lol.... just use all the injector tables from the tune with the 80's and copy it over to your gas tune that is setup for 60's then change your Stoich AFR back to 14.69 and you should be good to go for the most part. Nothing really very complicated.
Answer, yes you can. Should you, NO
Not if he doesn't have HPTuners and had someone else tune him. It's not as simple as putting the 60# fuel tables in the 80# tune. If you change injectors, you need to do a maf cal as well as changing it back to 14.7, but if he scaled the MAF and left it at 14.7, then the maf cal will be very skewed.
"Will a 60# tune work with 80#s on gas?"
