Weird fuel trims and AFR's
I'm in the process of getting my car to run better so I can one day pulley my TVS down.. I've notice my short and long trims are way out of whack. One of the 2 data displays on my interceptors usually reads -64.8 for short trims while the other data readout reads -10.5 to -20. I'm not sure why they read out different numbers. Both are bank 1. His happens while I am slowly driving around town. The two readouts both generally display around -12.5 on the highway. When I'm WOT it reads 0 which seems correct. Long trim is generally around -20.5...
What should I be looking for? Ives searched this forum and other forums and everyone is like **** tune... Which it might be since its trifecta. But I don't fully believe it's all the tunes fault.
The other thing I notice is my wideband is all over the place while normally driving. But fine while I am WOT or at idle. During normal driving it flutters between 14.6 and 16.8 in rapid succession. Like one second it will be 14.7 then the next its 16.1. And this is constant throttle with an engine load of around 31%
My roommate was saying look for boost leaks because of the weird fuel trims but before I go on the hunt for that I want to see if it could be anything else.
Mods: fully bolted (intake full exhaust cooling mods...) TVS on a stock pulley. 60's and 1 step colder plugs gapped to .032 I believe.
LTFT's (long term fuel trims) should usually be -/+5%, -preferred.
STFT's really read -68 ?????? something wrong there.
LTFT should be 0 or very near 0 @ WOT.
wide band should bounce back and forth around 14.7 crusin around,
02 sensor doing its job of telling ECM.... too rich... too lean and on and on and on.
Last edited by Staged07SS; 01-30-2014 at 12:49 PM. Reason: Lol, trims should be 0.8 at WOT?? Are u serious with that number??
Ya I have my doubts about the -68. I think my interceptor might be messed. It's weird as I can have the upper and low readouts both on the short trims and one will read the -10 to -20 and the other one reads from 0 to -68.5
What are the limits it should bounce for AFR's around cruising. My roommates turbo mx-5 stays fairly close to 14.7 whereas mine is only there for a split second while it bounces back and fourth between 14.7 to 16.1.
im going to say your tuner has no clue what he is doing
orrrrrrr you have a vac leak somewhere
AFR will never sit at 14.7 while cruising ... its going to fluctuate around but 14.7 - 15.5 is normal for cursing speeds.
if your interceptor is acting a fool make sure you have the correct STFT setup for your car look in the manual for the correct # code thing.
Log it with HPT and see what your twerkin wit.
He cant.
Vince has parameters wither shut off or blocked. I tried logging a Trifecta tune with HPT.
No way to tell because Trifecta.
I live in Canada and the car would still have to have been remote tuned. I have hpt sitting in my room but I need to buy a new laptop since I mainly use an iPad or a desktop. It's also winter so there's no point trying to tune it since I rarely drive it these days as I have a grand Cherokee as my winter vehicle.
I'm definitely thinking its a data error for the -60ish trim since it doesn't match the other readout on the interceptor.
HPT?
Interceptor?
