War Stories Post your racing wins. CobaltSS.net does not support or encourage street racing. Be smart and take it to the track.
Me Vs. "built" 350 firebird.
Old May 20, 2011 | 05:12 PM
brainchasm's Avatar
Originally Posted by SSSnoop
He better go home and get a stroker kit for his small block, and a crying towel for his pride.
I LOL'd.
Old May 21, 2011 | 10:29 AM
SSSnoop's Avatar
Originally Posted by BlueTurbo
How did you only get 350hp from a built 350? Modest budget 350's are easily capable of 400+
The reason I had 350 hp out of my build is easy - first, this build was about 10 years ago. Cam technology was good, but not as good as today. While you can get a great 400 hp now, then it meant some seriously low vacuum numbers and poor low end torque. The Camaro it went into had an automatic trans and power brakes. I didn't want to go with a vacuum can for the brakes, nor a higher stall converter for the trans.
Second, I used ported/polished/gasket matched 882 heads. They flowed well, but not as good as the Vortecs or any of the aftermarket heads out in my price range at the time.
And finally, this was off of a 2 bolt block with stock internals. And I don't care what anybody says, I do not think that 2 bolts, and even stock internal 4 bolts, are going to last long if you're making 400hp @6000rpm. If I had the money at the time, I would have pulled the rotating assembly and put in the stroker crank, and went ARP on the bolts all the way around. But money limitations have a way of smacking the dreams down.
Old May 21, 2011 | 10:42 AM
jmesl8er's Avatar
Did you at least go back and help him get his doors?
Old May 21, 2011 | 10:53 AM
Vetteman99's Avatar
hahahahhaha good stuff man
Old May 22, 2011 | 09:48 AM
BYT*SS*TURBO's Avatar
350-400 hp in a 4k+ lbs. car is still slow. If it's a stock trans it will dog off the line hardcore just like that also.
Old May 23, 2011 | 09:31 AM
BlueTurbo's Avatar
I hear you. For an extreme budget build a decade ago that is pretty good.
Tykuura
Nov 3, 2015 08:58 PM
patooyee
Oct 15, 2015 05:11 PM
Stuff
Oct 1, 2015 05:47 PM
riceburner
Sep 27, 2015 11:10 PM
lendsley
Sep 22, 2015 10:48 PM
