Scythe_Snake vs Modded T/A
You're missing my point. A 6758 efr balt on pump fuel vs you on an aggresive tune on pump fuel is a rough equivalent to a 100whp advantage over a 460hp t/a. Not trash talking, just saying.
Also take into account that a basically stock ls3 makes over 400whp with just a tune, exhaust, intake and cams. Guy in the trans am had more aggressive mods than that. Its possible he was on a happy dyno.
I still have no clue what car you are reffering to... My cobalt or Z28? Regardless, there is no replacment for displacment-Where are you getting this ls3 thing from? A LQ4 is a 6.0l iron block out a a truck... a ls3 is an aluminum 6.2l which replaced the ls2 that was a 6.0l aluminum block... There are no "cams" in an ls3 just one "cam". A bone stock ls3 is rated somewhere around 430hp and 430ftlbs. So your bolt-ons, cam and a tune should put you somewhere over 500hp on an ls3 (depending on how heavy your cam is) and supporting mods. The guy in the trans am had the absolute wrong setup for a N/A car. Nothing with his setup made any sense. People put lq4 blocks into there cars because they want to run boost because the lq4 blocks compression is low. Put that procharger back on that T/A and get things right and lets see a remtach- regardless that cobalt is one bad ass car.
Edit: If it were a Ls2 this is a GTO with similar mods for example.
http://www.youtube.com/watch?v=eC-DuZkWZDg
I would suspect that Scyth bringing his car to the track for quarter mile passes would surely be risking him grenading his transmission...
I don't doubt that the ZZP transmisson is better than the stock 320ft/lbs rating of the F35 ~ but probably not in excess of (or nearly) a 100% increase;
and the further torque multiplication yielded from the lower FDR might make matters worse.
I raced a 96 lt1 trans am ws6 and pulled 4 on the street on street tires and the next day at the track with him on m/t street legal radials I pulled almost 2 with him jumping and redlighting. I would love to find a LSx ws6
Oh yea, for sure. Some guy in a newer C4 tried to race me. Pretty sure it had an LT1, not sure which version tho. He tried to run me and I dropped a couple gears, stomped it and took off. About 5 seconds later when I slow down I get a ricer fly by from him, chase him down and pull right up on his ass and stay there as he tries to pull away. LT1s are nothing in stock form compared to the LSx series...
