2006 SS tire size question
Old Dec 16, 2006 | 07:02 PM
acelaman's Avatar
Question 2006 SS tire size question
What is the maximum witdh tire that I can put on our 2006 SS with stock rims?
Old Dec 17, 2006 | 02:04 PM
2K5SS/SC?'s Avatar
SS or SS/SC?
235's are pushing the limit on the SS/SC 18's. 225's are the best for the stock wheels.
Old Dec 17, 2006 | 02:07 PM
e to the x's Avatar
Originally Posted by 2K5SS/SC?
SS or SS/SC?
225s will rub and make loud noises as they catch the corner of the side skirt overlap in the fenders. It depends on how well the car was put together. I get rubbing on my passenger side but none on the drivers side with my 225/50R17 winter tires. The 3/4 inch of extra height might be the cause also.
Old Dec 17, 2006 | 05:23 PM
redss05's Avatar
anyone know if 225/40/18 will fit my stock ss/sc?
Old Dec 17, 2006 | 05:28 PM
SSCHRGD's Avatar
225/40r18 will fit without any rubbing or fitment issues. i am running 225/40r18 yokohama parada spec 2s and i love 'em. so you shouldnt have any issues. good luck.
Old Dec 17, 2006 | 05:36 PM
supa_chgd_07's Avatar
thats what im running right now
Old Dec 17, 2006 | 05:40 PM
p7x's Avatar
p7x
Easy fix, take off the wheel, push back the inner wheelwell at the same time applying heat to it with a heat gun, just until u feel the plastic start to give some. Hold it there and let it coo and ur laughin.
Im running that size and there is no rubbing.
Old Dec 17, 2006 | 05:42 PM
redss05's Avatar
thanks for the help
Old Dec 17, 2006 | 06:21 PM
redss05's Avatar
also ive heard that kuhmos have horrible sidewalls...anyone know if this is true? ive been looking at them but im a little hesistant because of what i ve heard
Old Dec 17, 2006 | 06:24 PM
M-Dub's Avatar
I'm running 225/40/18 Falken Ziex ZE-512s on my 06 SS/SC with the stock rims... no rubbing issues to date!!
Old Dec 17, 2006 | 06:43 PM
redss05's Avatar
do you like your falkens? ive been looking for tires for about 2 weeks now...im trying to find a good all season tire (i live in northern pa) i like the kuhmos but ive heard some bad stories.... ive checked out the falkens also
Old Dec 18, 2006 | 12:45 AM
M-Dub's Avatar
I love them... my buddy has them also... I have had no problems in 1000 miles, he's had his for 12,000 miles and not one problem! They don't seem to have quite the grip off the line... But they seem to grip as well if not better in cornering, and braking... in the snow and rain... THERE IS NO COMPARISON!
Old Dec 19, 2006 | 06:06 AM
acelaman's Avatar
Original post was in regards to a 2006 SS 2.4 Not an SS/SC. These come from the factory with 17's.
Old Dec 19, 2006 | 04:16 PM
redss05's Avatar
anyone using nitto neo gens?
Old Dec 19, 2006 | 04:54 PM
M-Dub's Avatar
Well there was a question posted earlier that stated SS or SS/SC? With no responce from you as to which!
Old Dec 20, 2006 | 04:48 AM
Skitz's Avatar
Your rubbing because you got the 225/50's and not the 225/40's. Even though the stock tire size is 215/45 - when you switch to a 225/40 all you get is a wider tire with the same height as the 215/45/18. It's just the way the tire is built - even though the size would suggest it isn't at tall because it's a 225/40/18.
What's great about this is:
A. Your speedo will stay the same because of no height change
B. 215/45/18 give you limited choices (ONLY 4)
- While a 225/40/18 gives you 26 to choose from.
Sorry $200+ for this Pirellis is outrageous for that tire when you could get a BF Goodrich g-Force T/A KDW NT for $160 and it's a 10 times better tire.
Now obviously you don't always have to shop at Discount Tire I was just using it as an example.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
dieGone
Oct 1, 2015 06:27 PM
Iceberg
Sep 28, 2015 01:31 PM
