Anyone else noticed this or is it just me
Old Mar 9, 2010 | 09:56 AM
roser4888's Avatar
I had new tires installed on my 05 ss/sc. I went with a 225/45r18 instead of the 215/45r18. Well long story short my right rear wheel is rubbing my fender and tearing up my tire. I noticed that my left front sits in about a half in further then the right rear does.
Old Mar 9, 2010 | 10:01 AM
BLAZIN07SS's Avatar
I'm too JDM for you
are you lowered? shouldn't be rubbing with that little change in width
Old Mar 9, 2010 | 10:03 AM
Bika's Avatar
Fail Less.
People run much wider than that w/o problems. I just bought that same tire size and will be installing shotly.
Old Mar 9, 2010 | 10:05 AM
BLAZIN07SS's Avatar
I'm too JDM for you
im on 17x9 wheels with 245/40/17's on sportlines and i dont rub. lol
Old Mar 9, 2010 | 10:07 AM
Supercharged06's Avatar
iv been running 225 40s 18s for years now even when i was lowered to the max on coilovers i didnt rub and when i say max i mean i had to tuck the front tires under the fenders lol
Old Mar 9, 2010 | 10:13 AM
roser4888's Avatar
Originally Posted by blazin07ss
are you lowered? Shouldn't be rubbing with that little change in width
yes i am lowered. I just dont understand why the right tire sticks out soo much more.
Old Mar 9, 2010 | 03:33 PM
Bumpin Balt's Avatar
It's the extra height of the 225/45/18 tire. They are almost half an inch bigger than 215/45/18's. The fronts tuck in the fender wells more than the rears. Your camber could be a bit off up front also. I don't know why Tire rack recommends 225/45's. Most SS owners run 225/40's or 235/40's.
Old Mar 9, 2010 | 04:50 PM
roser4888's Avatar
Originally Posted by bumpin balt
it's the extra height of the 225/45/18 tire. They are almost half an inch bigger than 215/45/18's. The fronts tuck in the fender wells more than the rears. Your camber could be a bit off up front also. I don't know why tire rack recommends 225/45's. Most ss owners run 225/40's or 235/40's.
i just looked at the alignment sheet the camber, caster and toe are all perfect
Old Apr 29, 2010 | 09:49 AM
joddypoo's Avatar
I just got 225/45R18 's and notice rubbing on front passenger tire when front end loading (braking) and turning to the right. I'm guessing mine at least has more to do with diameter (9mm bigger overall than stock) than width cause it doesn't rub when going slow and turning for me...
Still I'm surprised nobody had mentioned this... and I can't seem to find anything hanging or loose in the wheel well.
Old Apr 29, 2010 | 11:03 AM
I have heard of a few people having rubbing issues with 225/45/18's. That's why I always recommend 225/40/18's or 235/40/18's.
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
importkiller
Sep 30, 2015 07:18 PM
cw383
Sep 30, 2015 12:41 AM
