So a fellow HHR owner wrote this about my new setup:
Sorry, my 2c, but trying to make it look like a slammed Subi, why not just get one? Far better power, AND looks wise... I mean, I like the Depos, and the stickers and all.. But the gold rims, and yellow fogs...
I'll take that as a compliment! lol
Hopefully I join the wheel club after taxes!
I am looking at the STR 521 17x9+20 Some of their styles I like only start at 19' and I'd like to go 17 and run super sticky tires. I enjoy the back roads and traction on my LSJ-t too much lol
Since you guys are the wheel experts I'm reposting this in this thread to get an answer. These are going to be winter wheels so stance isn't very important, I just want to be 100% positive they'll fit over the Brembos. Thanks in advance.
This is probably a repost, but I went back a few pages and didn't see anything on 17" Drag DR-19's fitting over the Brembo's. I saw a few other Drag wheels fit, but I'm curious about these. Looking at these for a winter tire/wheel setup because they are some of the cheapest and don't look like garbage.
Specs are as follows:
Wheel Size
17 x 7.5
Bolt Pattern
5/110, 5/115
Wheel Offset
42mm
Hub Bore
73.00
Weight
20 lbs
Wheel Size
17 x 7.5
Bolt Pattern
5/110, 5/115
Wheel Offset
42mm
Hub Bore
73.00
Weight
20 lbs
based off specs alone wont get your answer, i would say yes based off specs. but really the shape of spokes are the determining factor as brembos are massive as fuu hahaha
are you able to contact the seller or test fit them?
maybe some info in here
http://www. cobaltss .com/forums/showthread.php?t=11769
take away the spaces
The SS/NA wheels I picked up fit over the Brembos without a spacer. By fit I mean you can't shove a piece of paper in there without it practically shredding, but they do spin without hitting anything. I'll be getting extended studs to allow for the 5mm spacers I have, could probably get away with 3mm spacers and OEM studs.
It's through an online tire company so I have an email into them. It says the rim will fit in an 18", but this site doesn't give alternative rim sizes like tirerack does.
Try something new, if i could go back in time i would have gotten something other than the ES2. no one around me has them, so thats a bonus, but there is plenty of definitely other wheels that haven't been done yet that would look very good.
