What size wheels and tires are those? I got the same car and wanna go with the same rotas and wanna run coils, love how yours looks and would like to do the same
New wheels will be here on Monday...gonna be a long weekend!
Question...there's a lot of noise coming from the rear of my HHR...creaking and squeaking. I get under the car once a week and pull the rear coils out and WD everything. Seems like it's a little quieter for a few days then back to the sounds. This is the first car I've ever had coils on...is this the norm or could I have something going on? I've got Ksports with all locking rings removed.
I'm getting used to mine too...you can't really hear it outside the car...the hatch area kinda amplifies it through the car. I'll try some of that lithium grease and see if it works any better. Appreciate the help...
http://seattle.craigslist.org/est/pts/4669248946.html
Welp look what just popped up near me, these would look so much cooler than my 18x8 et40 enkei m52s lol.. but how to make them fit? I think id get crazy poke even if I run a 20mm adapter. But im not 100% certain of this. Anyone run staggered wheels on their balt?
The 18x9.5 with the 38mm with a 20 adapter brings it to a 18mm. that would be real aggressive for the rear. it would poke a lot. The 8.5 wouldn't be all that bad though. you would probably have to run a 215/40 on that and probably still hit the fender
i see youll do adapters which will require some fender rolling and some slight pull.
if u did a redrilled hubs the fronts would be fine. the rears would probably touch on the inside with that offset
+18 final offset all around is plenty good clearance on the inside, it will poke for sure
a gang of guys have ran staggered
So it sounds like redrilled is the way to go.. id like to run a 235 or 245/40 tire as im planning on putting go fast parts on as well. With a redrill I should be okay maybe with a slight roll/pull or a few degrees of camber in the rear? (Nothing stupid). Heres the catch though, im on sportlines.. no coils, yet.
I think theyll clear the brembos but if not I could do a 5mm spacer up front and it should make them fit pretty good.
Whats a redrill usually run?
u can get redrilled hubs for 320 shipped from jeff on here
the white car is on 17x9
im running 9.5 all around +30 with 5mm spacers on the front. rolled and slight pull on the good ole fenders
its really close on the rear. thats why the +38 on those wheels is probably touching on the inside
