Old Sep 17, 2014 | 06:03 PM
  #12251
raduenz28's Avatar
Originally Posted by SS-C4RP3NT3R-SC
Been a while since I've been on these forums, use to be to much drama lol but seems to be calm and well rounded now
What size wheels and tires are those? I got the same car and wanna go with the same rotas and wanna run coils, love how yours looks and would like to do the same
Old Sep 17, 2014 | 11:04 PM
  #12252
block_00 by DS_Mastery, on Flickr
the block is hot
Old Sep 17, 2014 | 11:59 PM
  #12253
block_03 by DS_Mastery, on Flickr
Old Sep 18, 2014 | 03:01 PM
  #12254
MaxDugas's Avatar
Seems to be Varrstoen ES2 powdercoated in purple.
Old Sep 18, 2014 | 03:19 PM
  #12255
Empty Pockets's Avatar
look like rota grids to me
Old Sep 19, 2014 | 02:11 PM
  #12256
Kyle09TC's Avatar
Definitely Rota Grids, I won't remember the exact set up or offset, but it was on adapters (22-25mm?) and they were a 17x9 with a 215/40 tire, i think. Probably not 100% correct, but I imagine that is close to the set up.
Old Sep 19, 2014 | 04:56 PM
  #12257
sounds pretty close to me ^ final offset was 0 in the front... mahbe haha
Old Sep 22, 2014 | 01:44 PM
  #12258
chefhhr's Avatar
Hoping to finally join the ranks here end of the week. My STRs should be here by Friday...just hoping they get me the right fitment.
Old Sep 22, 2014 | 04:57 PM
  #12259
what did u end up going with?
Old Sep 22, 2014 | 08:49 PM
  #12260
chefhhr's Avatar
18x8.5 +30 STR 601s. I figured if it doesn't get me the fitment I want I'll pick up 9.5s with tax return and sell the 8.5s. I think I'll be able to keep it low and get a nice stance with the 8.5s.
Old Sep 22, 2014 | 10:36 PM
  #12261
yea u should be fine and youll figure it out once u have all the pieces
Old Sep 23, 2014 | 06:52 AM
  #12262
murphxrockstar's Avatar
Looks like I'm keeping her since no one wants to buy anything so I might as well finish her. Here's a pic of her before she's in pieces lol. Sorry for the shitty iPhone pic.
Old Sep 23, 2014 | 04:51 PM
  #12263
glad to hear you decided to continue onward
Old Sep 24, 2014 | 08:45 AM
  #12264
chefhhr's Avatar
New wheels will be here on Monday...gonna be a long weekend!
Question...there's a lot of noise coming from the rear of my HHR...creaking and squeaking. I get under the car once a week and pull the rear coils out and WD everything. Seems like it's a little quieter for a few days then back to the sounds. This is the first car I've ever had coils on...is this the norm or could I have something going on? I've got Ksports with all locking rings removed.
Old Sep 24, 2014 | 08:57 AM
  #12265
Try using spray lithium grease. It will stay longer than wd40 will. My car creaks and squeaks too but i got used to it
Old Sep 24, 2014 | 01:42 PM
  #12266
chefhhr's Avatar
I'm getting used to mine too...you can't really hear it outside the car...the hatch area kinda amplifies it through the car. I'll try some of that lithium grease and see if it works any better. Appreciate the help...
Old Sep 24, 2014 | 02:13 PM
  #12267
Being low is gay.
Old Sep 24, 2014 | 06:23 PM
  #12268
but does it hover
Old Sep 25, 2014 | 10:36 AM
  #12269
TylerJY's Avatar
http://seattle.craigslist.org/est/pts/4669248946.html
Welp look what just popped up near me, these would look so much cooler than my 18x8 et40 enkei m52s lol.. but how to make them fit? I think id get crazy poke even if I run a 20mm adapter. But im not 100% certain of this. Anyone run staggered wheels on their balt?
Old Sep 25, 2014 | 11:05 AM
  #12270
Kyle09TC's Avatar
The 18x9.5 with the 38mm with a 20 adapter brings it to a 18mm. that would be real aggressive for the rear. it would poke a lot. The 8.5 wouldn't be all that bad though. you would probably have to run a 215/40 on that and probably still hit the fender
Old Sep 25, 2014 | 11:07 AM
  #12271
those would fit just fine, well the fronts yea haha
i see youll do adapters which will require some fender rolling and some slight pull.
if u did a redrilled hubs the fronts would be fine. the rears would probably touch on the inside with that offset
+18 final offset all around is plenty good clearance on the inside, it will poke for sure
a gang of guys have ran staggered
Old Sep 25, 2014 | 11:38 AM
  #12272
TylerJY's Avatar
So it sounds like redrilled is the way to go.. id like to run a 235 or 245/40 tire as im planning on putting go fast parts on as well. With a redrill I should be okay maybe with a slight roll/pull or a few degrees of camber in the rear? (Nothing stupid). Heres the catch though, im on sportlines.. no coils, yet.
I think theyll clear the brembos but if not I could do a 5mm spacer up front and it should make them fit pretty good.
Whats a redrill usually run?
Old Sep 25, 2014 | 11:42 AM
  #12273
TylerJY's Avatar
I really like how this car sits. I just dont know how to achieve that on my car.
Heres the stance id be shooting for, not crazy low, no need for stretch imo
Old Sep 25, 2014 | 01:31 PM
  #12274
u can get redrilled hubs for 320 shipped from jeff on here
the white car is on 17x9
im running 9.5 all around +30 with 5mm spacers on the front. rolled and slight pull on the good ole fenders
its really close on the rear. thats why the +38 on those wheels is probably touching on the inside
Old Sep 25, 2014 | 02:00 PM
  #12275
TylerJY's Avatar
So I would probably need to redrill the hubs and run spacers since the smallest adapter I'd want to run is 20mm and that would be way too much poke correct?
