Reflash
Old Jun 1, 2006 | 11:05 PM
redlineblueline's Avatar
Reflash
Will GM reflash the comp for bigger/better tires/rims without much hassle and whats it going to cost?
Old Jun 1, 2006 | 11:52 PM
Doc's Avatar
Doc
I went in and they didn't have anything. They even called GM...they were waiting on a call back, that was almost a month ago.
Old Jun 2, 2006 | 09:07 AM
That sucks I don't want my speedo/odometer to be way off and I was hoping I could talk the guy into raising the limiter.
Old Jun 4, 2006 | 05:20 AM
Badmunky's Avatar
Just get a tire that is the right size. You can get a bider rim and a wider tire and not mess uo the speed O.
Later
Old Jun 4, 2006 | 08:55 AM
Bishop's Avatar
So how much did the reflash cost.
Old Jun 4, 2006 | 09:03 AM
turboeco's Avatar
My Intense PCM was reflashed for 225/40/18 tires. I didn't want my speedo to be off, so they were nice enough to change it for me.
Old Jun 4, 2006 | 11:45 PM
Clmbngfrk18's Avatar
my dealer said they could do it but only with certain tire sizes he said to call ahead to make sure they can do the tire size i want
Old Jun 5, 2006 | 12:18 AM
Malaclypse's Avatar
I checked up on this and found you can only really have the car programmed for 195/60-15s or 205/55-16s. They're both the exact same and the same tire height as stock so its pointless. I called Techline and Tech Assist and neither had an answer for me.
NOTE: This is only true for 2.2 cars.
Old Nov 1, 2006 | 12:02 AM
CobaltCoupeCrazy's Avatar
They can reflash for the speed rating of the tire. There are two speed ratings on the
15's. Also the 195/60 15 is 615mm total height and the 205/55 16 is 631.9mm total height. The circumfrence of the 16's is 53mm greater.
I don't know about reflashes for speedo calibration. I only know of the reflash for the top speed limiter.
bigdogstokes16
Oct 8, 2015 10:28 PM
NoBalt123
Sep 4, 2015 07:10 AM
cobss187
May 12, 2006 06:02 PM
Xenozx
Apr 23, 2006 03:13 PM
1MEANSS
Apr 22, 2006 02:56 PM
