Torque spec for 18" on SS?
Old Apr 29, 2006 | 01:03 AM
Zonomar's Avatar
I read it is 100 somewhere on the forum, but it didn't say which wheel/car.
I don't know if that makes a difference.
Old Apr 29, 2006 | 01:20 AM
SilverSS/SC's Avatar
100 ft/lbs
Old Apr 29, 2006 | 02:26 AM
Xenozx's Avatar
what do you mean by torque spec?
Old Apr 29, 2006 | 02:41 AM
Zonomar's Avatar
Thanks - it is how tight to do up wheel nuts.
I guess its 100 for all Cobalts then.
Old Apr 29, 2006 | 01:47 PM
qcpursuit's Avatar
100 for all cobalt and all gm cars
Old Apr 30, 2006 | 05:22 PM
Floridas Finest SS's Avatar
it says it on the door frame to your left when your sitting in the driver seat you have to have the door open but it also says how much air to put in the tires.
Old Apr 30, 2006 | 08:37 PM
WJT DEMON's Avatar
I go by the "aluminum wheel 100 ft/lbs and steel wheel 90 ft/lbs" rule for any car.
Old May 16, 2006 | 12:29 AM
zinner's Avatar
Moderator Alumni
I second 100 ft/lbs
I think it's in the owners manual.
If the aren't tq down correctly the rotors will warp or worse yet the wheel will fall off.
Old Jun 17, 2006 | 02:09 AM
Pyros777's Avatar
100ft/lbs is common for most cars, so it sounds right to me.
Old Jul 23, 2006 | 02:40 PM
Kemo's Avatar
Pretty much 100 for EVERY car unless noted on vehicle otherwise.
Old Oct 20, 2006 | 07:23 PM
n8dogg's Avatar
gray torque stick
Old Oct 20, 2006 | 07:34 PM
Imlikedrpepper's Avatar
Do not go any tighter, you will strip the bolts, or you could distort the rim. A guy at the dealership I go to shoulded me what someone did when they tightened it too tight, lets put it this way, the rim was good as a paper weight.
Old Oct 20, 2006 | 08:25 PM
Boosted_SS's Avatar
it is definately 100 ft/lbs i work at sears auto center and the torque spec we have is 100 ft/lbs. now what we normally recommend especially with aftermarket wheels is after we torque them down and you drive 100 miles on them you re-torque them to make sure they are still tight. i've seen quite a few wheels fly off because people forgot to re-torque their wheels often enough.
Old Oct 20, 2006 | 09:40 PM
rally's Avatar
ALL GM vehicles except trucks use 100ft/lbs. Other cars such as honda use usually 78-83 ft./lbs. So most imports use lower torque where as domestics generally use 100.
Old Oct 21, 2006 | 12:10 AM
Boosted_SS's Avatar
thanks for the information captain obvious!! it's a good thing you posted that cause we might have missed it the first 5 times it was posted on here. geez good thing you came along or else we would have been putting the wheels on with super glue!
Old Feb 15, 2007 | 04:17 PM
Erod's Avatar
Moderator Alumni
Ok adding this to main info post and un-sticking.
Old Feb 20, 2007 | 12:52 PM
FraGmE's Avatar
lol bad day?
Old Feb 20, 2007 | 08:19 PM
Boosted_SS's Avatar
lol no just busting his ***** alittle
Old Feb 20, 2007 | 08:25 PM
jeremie's Avatar
i go by the impact rule..
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
TedSS
26
Oct 10, 2015 04:30 PM
Builttss
Oct 4, 2015 10:21 AM
