ZZ Performance ZZ Performance is a proud Supporting Vendor
7163 zfr
Old 11-19-2014, 03:33 PM
  #151
alerosaint's Avatar
Originally Posted by Matt M
I'm not sure if this has been talked about on here or not. The 7163 introduces a new aluminum center section housing. These turbos are extremely lightweight and also make a little more noise than the 6758.
videos of said noise?
Old 11-29-2014, 08:36 PM
  #152
billythakid's Avatar
matt
Matt I order a 7163 from yall will I need a new intake or will the k&n work and is there any new info you can give out thanks
Old 11-29-2014, 09:17 PM
  #153
7163 is worth about 30whp over the 6758 on setups running 25+ psi. It is a good choice for 25psi on pump gas or 27 psi on E85/E47.
Old 12-03-2014, 02:02 PM
  #154
Matt M's Avatar
K&N intake should work fine. It's a tight fit on the compressor cover, but it will go on.
Old 12-03-2014, 02:03 PM
  #155
Matt M's Avatar
Housings are supposed to be complete in about a week or so. We are still on track to ship 7163s by mid December.
Old 12-03-2014, 02:08 PM
  #156
taintedred07's Avatar
Are you going to post max whp dyno sheets as before with the 6758 years back?
Old 12-03-2014, 02:16 PM
  #157
AaronJ's Avatar
I'm still holding out for some videos of the 7163
Old 12-03-2014, 03:51 PM
  #158
Wert842's Avatar
Ahhhh. An extra 30horse over the 6758 for an additional $500. That's like an $16 a horse. Not too shabby.
Old 12-03-2014, 04:16 PM
  #159
Terminator2's Avatar
Might be closer to 50 whp difference if pushed to 29 psi.
Old 12-03-2014, 04:21 PM
  #160
hawkssoccer11's Avatar
seems to me mr.powell will be getting busy with rebuilding 4.45 trans now haha guess people better start getting 6spd trannies from saabs since the 4.45 is gone hahaha
Old 12-03-2014, 04:27 PM
  #161
That sounds like the 7064, I thought this turbo was rated decently higher?
Old 12-03-2014, 04:46 PM
  #162
Close to 500whp at 29psi on 93 not enough?
Old 12-03-2014, 05:01 PM
  #163
Thought it was e85 or a mix nevermind
Old 12-03-2014, 05:36 PM
  #164
IDK Werts car is almost 450 whp on a 6758 29 psi and 93 so I would hope this one could get close to 500whp on 93 at same boost levels same car same dyno.
Old 12-03-2014, 05:57 PM
  #165
user 72239's Avatar
500 whp is not enough for a FWD car.
Old 12-03-2014, 08:24 PM
  #166
Old 12-04-2014, 10:02 AM
  #167
Not for some people
Old 12-05-2014, 05:14 AM
  #168
brianhud1991's Avatar
hahaha I think 500 whp is more than enough for a FWD. Have to have all the suspension goodies and thick slicks to even remotely have traction.
Old 12-05-2014, 10:28 AM
  #169
user 72239's Avatar
Anything above 350 is stupid IMO. My car with the 30 psi ZFR tune was nuts. However eric's car on his 24 psi K04+ is like the perfect combination of power delivery and grip.
Old 12-05-2014, 10:33 AM
  #170
LNFwagonSS's Avatar
Anyone think there is any way to make 550whp with this turbo on the LNF?? What setup would be needed?
Old 12-05-2014, 10:34 AM
  #171
I like nuts.
Old 12-05-2014, 10:36 AM
  #172
user 72239's Avatar
I like nuts.
So gay David.
Old 12-05-2014, 10:38 AM
  #173
Hmm E-47 or E-85, 32-33psi and enough fuel to support it (5th injector most likely needed to have enough fueling room especially as the injection window gets shorter as the RPMs rise. Stock trans would likely die fast with the torque hit most likely but not sure how much of a torque monster this turbo is yet.
Someone get one on and let me see what it will do.
Old 12-05-2014, 10:46 AM
  #174
LNFwagonSS's Avatar
Will have the f40 installed soon so no worries there. Fifth injector also? So that means the Opel + fuel lobe combo won't be enough on e85? What would the Opel + fuel lobe max at approximately?
Old 12-05-2014, 11:04 AM
  #175
Opels, big fuel lobe, max safe rail pressure and maxed out injection start angle E-47 roughly 510-520whp maybe a touch more. E-85 with 14% more fuel demand 450whp or so safely. More than that will be very risky. Colodude's ZFR at 480 whp is maxed on E-47 stock injectors stock cams but he is at 6000ft so his dyno has a 23% correction factor.
Quick Reply: 7163 zfr
