adjustable tensioner question
i just got this in the mail and had a couple questions. i currently have a 2.8 inch pulley with the stock belt and the oversized tensioner pulley. which hole should i use? the instructions that came with it didn't describe the hole locations.
also, how much tension should the belt have on it? i think even with the os pulley on i still have some belt slip. sometimes i find what i think is rubber "dust" on the snout of the supercharger by the SC pulley
I have the adjustable tensioner and I'm running a 2.8 with the stage 2 belt and regular tensionerpulley and I'm using the hole all the way to the left. Since your on a 2.8 with stock belt and os tensioner pulley I'd guess you'd use the same hole as me. Here's a pic of the instructions. If you had the regular tensioner pulley you would be using hole 2 but bc your have the bigger tensioner pulley you're going to need to use hole 1
