ZZ Performance ZZ Performance is a proud Supporting Vendor
fuel pump rewire
Old Jan 29, 2013 | 07:21 PM
briank6102's Avatar
Uhm... not exactly sure how to check with the cover off other that using a multi-tester.. it does not say on the relay itself besides on the casing where it says 40-AR-B 40A\28VDC DC12V.. I don't know. Mines worked withno problems for almost a year now
Old Jan 29, 2013 | 08:12 PM
Tjolley's Avatar
Drive your car around for about an hour and then go back and feel the relay if it's hot there something wrong...... but also feel the wires my wires were cold
Old Jan 30, 2013 | 04:18 AM
EmperorJJ1's Avatar
looks legit... somewhat. let me get a pic of a bosch one up to compare
Old Jan 30, 2013 | 08:38 AM
freakta's Avatar
I'm sure they were install error
Old Jan 30, 2013 | 10:25 AM
OneCOLDBIZL272's Avatar
Wired in per-install instructions sent with it from vendor....
Old Jan 30, 2013 | 10:31 AM
I had this happen to mine over 2 yrs ago. It didn't even last but, 2 weeks.... Current setup has been good for yrs...not one issue
Old Jan 30, 2013 | 12:03 PM
ebristol's Avatar
But with your car there were probably other problems.
Old Jan 30, 2013 | 12:28 PM
Yes but I've never had problems with anything since my rule of only two people I allow to work on it. Me being one of them. Cars been good since....but a heavily modded car is bound to have problems here and there. Cars been fine and running strong.
Old Jan 30, 2013 | 12:33 PM
Back to the tread about the rewire kit
Old Jan 31, 2013 | 08:03 PM
Tjolley's Avatar
Ill be using a fuel pump wiring kit from jegs wen i make my duel intank canister..one pump will run at all times the other will be on a switch cuz u don't need both running all the time..
Old Jan 5, 2014 | 07:40 PM
  #36
CCrunner84's Avatar
Figured I'd bump this, mine burned up this weekend after a year or so of use, fuse never popped either. I'll keep tabs on the replacement one, hopefully it won't happen again anytime soon...
Old Jan 5, 2014 | 08:43 PM
  #37
06cobalt racer's Avatar
Sub'ed. I have one from ottp I have yet to install.
Old Jan 20, 2014 | 01:53 PM
  #38
bmxracerchamp12's Avatar
i just bought a complete fuel system from them including the rewire kit
Old Jan 20, 2014 | 03:44 PM
  #39
thats what i got to. the return system and this
Old Jan 20, 2014 | 07:25 PM
  #40
now why run both? i have had 2 people tell me to with no explanation
Old Jan 20, 2014 | 07:33 PM
  #41
They do too different things. The rewire helps to make sure the pump is getting the full voltage. The return system let's you adjust the fuel pressure and ensures all cylinders get fuel.
Old Jan 21, 2014 | 06:48 AM
  #42
i have the boost reference but i see everyone runs both. just curious as to why?
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
