ZZ Performance ZZ Performance is a proud Supporting Vendor
Zzp Lsj Pcm...???
Old Jun 9, 2008 | 07:38 AM
LamboW9's Avatar
yea it is i guess...when i fill mine up it reads empty....i've called zzp after i installed it an they wanted me to send in my pcm i just told them i'd deal with it for now and they can research it an call me when they figure out the problem
Old Jun 9, 2008 | 10:45 AM
kwest's Avatar
WTF? so you filled up your car and your gas gauge said it was dead empty?? yea i hope i dont have that issue cause i dotn want to go through the trouble of returning it and everything
Old Jun 9, 2008 | 10:47 AM
LamboW9's Avatar
yea i'm contemplating asking zoomer what is up because the other guy jus said he had the same problem....its wierd and annoying but doesnt affect performance and i couldnt really send it back considering my car was off the road for a week waiting to get it back along with the stage kit so i just told them to research the issue an call me when they had a solution...but it is verry annoying but the kit does run verry well
Old Jun 9, 2008 | 11:19 AM
zay52790's Avatar
zzp should def figure out wtf is with the as guage. I went through a massivly lame ordeal and had to push my car 5 blocks thatnks to them. Oh well. At least the car runs nice. They should def figure out what the problem is and how to fix this. Anyone know if this will go away if i get the car dynotuned?
Old Jun 9, 2008 | 11:25 AM
LamboW9's Avatar
so thats wat the problem was huh zay?
and i believe it is somethin in the pcm with their reflash...so if you get it dyno tuned an the reflash the pcm an check everything i'm sure they are probably just missing something..ima pm zooomer the link to this thread so he see's otheres are having this problem as well
Old Jun 9, 2008 | 11:27 AM
hungryhip-ccp's Avatar
the 05-06 ecm is different than the 07 and if you interchange them you will get a backwards reading gas gauge...but thats all no harm... how does no one know this? i did a search and found your answer in under 20 seconds...
another thing thats funny how did you guys actually run out of gas... the farther you drove the more gas you got!!! that didnt seem odd to you
Old Jun 9, 2008 | 11:32 AM
LamboW9's Avatar
i havent ran out of gas but is there no way to fix it....and they tune for our vin's and year so wouldnt they know that? and my pcm is the one i sent to them that they reflashed an sent back...its not one of their pcm's
Old Jun 9, 2008 | 11:39 AM
well then it was obviously loaded with a canned tune that was from a 05-06 model i have there tune as well and i sent them my ecm also and mine is right i have a 07 and it reads normally... i dont know if you noticed but for a while on the website they had it only availible for 05-06 that was beacause of this issue... well i had someother issues with them like selling me a high flow dp that would throw a 420 code... so what they offered mye was to do a cat code delete at no charge if they could barrow my pcm to do a 07-tune this was early 07 and which i also recieved there canned tune at a discounted rate... dont know how much this helps you but yeah...
Old Jun 9, 2008 | 11:45 AM
LamboW9's Avatar
i have an 06 thats the point...they musta sent me a tune from 07..i called them an they said they had no idea wat could have caused it
Old Jun 9, 2008 | 12:48 PM
thats funny they should know exactly what caused it... i hope there not giving you thee old "cold shoulder" hoping you'll go away... it's not right and im sure you paid good money to do it right... if they dont even know what they did to your ecm, that would scare the **** out of me... what else did they forget/dont know what they did with that tune...
Old Jun 9, 2008 | 12:50 PM
  #36
LamboW9's Avatar
well i pm'd zooomer with a link to this thread and i'm hoping i can get it fixed like the others on here...the stage kit from them is great an i'm pretty happy with their products...and i'm positive that its not intentional...i'm sure zooomer will get back to me
Old Jun 9, 2008 | 12:59 PM
  #37
yeah zzp can be really great... and i do love there product too... and theyve been around for awhile... so theyre probably not going anywhere soon and i like that as well...
Old Jun 9, 2008 | 10:54 PM
  #38
kwest's Avatar
hmm this worries me. Im calling them right now cause my SS is an 06 and i want to make sure they have this kink worked out before i install it in my car cause i dont want my gas gauge to be doing that, even if it doesnt affect the actually driving of my car.
well of course i didnt get ahold of zzp...for some reason their phone always has a busy signal. i just tracked the pcm and its going to be here tomorrow afternoon but i doubt i will get everything installed tomorrow (pcm and 60s) but hopefully wednesday or thursday. ill keep you guys updated to see how well it works for me.
?? due to the heat, shoudl i go up a pulley size? im seriously thinking about this for i believe my car actually pulled harder with my stage 2 pulley on. and i know its been proven with zzp's pcm that they make more power with the 3" pulley versues a smaller one..
Old Jun 10, 2008 | 12:48 AM
  #39
LamboW9's Avatar
i'll race my buddy he has a gm stage 2 with a 2.9 pulley..an no exhaust....i'll race him...i now have a full exhuast with a zzp stage 3..........afterwards i'll let you kno if i beat him or not an how close it was
Old Jun 10, 2008 | 12:52 AM
  #40
kwest's Avatar
sweet. a vid would be nice too. im thinking about upgrading my heat exchanger also...im trying to get the engine as cooled as possible, cause in texas it gets pretty much 100 degrees everyday during the summer. do yall know which heat exchanger has the built in coolant tank to lower temps even more?? cause i dont wanna run the dual pass mod cause of the surge tank....
Old Jun 10, 2008 | 07:47 AM
  #41
LamboW9's Avatar
the Heat exchangers are only 60% efficient so your only getting another 60% cooler....if you want max cooling and power....spend another 200 an get the meth kit from AIS....you DO NOT need a tune for it however you'd put more power down if you did tune for it but if you don't then it keeps your engine safe an all it does is spray a mix of water/methanol into your engine an the water helps keep it cool while the methanol boosts your octane which pretty much eliminates the occassional (bad gas) that we get that pings every now an again....the meth over the h/e is far more cost effective
Old Jun 10, 2008 | 02:54 PM
  #42
x2
Old Jun 11, 2008 | 12:02 AM
  #43
kwest's Avatar
man, it really sucks that you spent all that time typing and explaining that for me when all you had to REALLY do was look below in my sig and you would have noticed AIS STAGE 1 ....
oh and to add to that, if you go to the customers pictures on AIS's website, you MIGHT find my car there...hahaha!!! http://www.alcoholinjectionsystems.c...icle_info.html
Old Jun 11, 2008 | 07:50 AM
  #44
LamboW9's Avatar
then if you have an h/e and meth you should have no worries of heat problems....now my dam car is studdering in first and second an then smoothing out ....its only in the beginning of the first an second gear...once she gets going she is good or if i slip the clutch a bit so when it bites it is at a higher rpm its good also....i just installed the zzp header/dp combo so is it possible that the pcm/ecu is still learning the new setup?...and i had previously gapped my plugs at .40 and with the zzp stage 3 it ran great with just a cat-back but now its doing this so maybe i just need to regap?...any help would be appreciated
Old Jun 12, 2008 | 09:58 PM
  #45
advise's Avatar
did you guys need to do a case relearn and or security relearn with the re flashed PCM
Old Jun 12, 2008 | 10:08 PM
  #46
LamboW9's Avatar
you only need to do a case relearn if you order their pcm an keep yours as well...if you send them your pcm that came in the car then you do not have to do a case relearn
Old Jun 18, 2008 | 02:37 PM
  #47
kwest's Avatar
do you guys know if you should disconnect the battery when installing the new pcm or what?
Old Jun 18, 2008 | 02:47 PM
  #48
LamboW9's Avatar
you should have disconnected it when you removed it to begin with so yes disconnect it before you hook it back up....then reconnect it and pull your fuel fuse so you can drain your fuel lines so you can begin dismantling your injectors an fuel rail....once the car idles an shuts off (no fuel)...then disconnect the batter an put the fuse back in an start puttin in that stage kit....btw zzp said they fixed the fuel gauge backwards problem....i'm sending mine in at the end of the week to get reflashed an fix it
Old Jun 20, 2008 | 04:05 PM
  #49
kwest's Avatar
UPDATE: i got my 60s installed and the zzp pcm. car runs so smooth and i can definetly feel it pulling alot harder in 2nd car, cause 1st gear goes by pretty quickly..haha however my fuel gauge is backwards, so i might winde up sending it off to them again for them to fix it, i just cant go a week without my car since its my daily driver. so far everythings great though, a lil rich of a tune, buts its waaay better then my stage 2 tune. overall, im satisfied.
Old Jun 30, 2008 | 02:11 AM
  #50
kwest's Avatar
well, the car started running like crap. i was quite irritated. the car was hesitating and bogging down terribly when shifting. so what i did was unhook my methanol and it seemed to make a big difference. so now im lost....im bout ready to sale everything!!!
