Draining Coolent
Old Jan 24, 2008 | 02:59 PM
mkulrey13's Avatar
Draining Coolent
Anyone know how to drain our coolent, there is no plug that i saw on the radatior. If its a hose which one? thanks
- Mike
Old Jan 24, 2008 | 03:02 PM
D4u2s0t's Avatar
there should be a plug, i THINK it's on the water pump or by the water pump at least. to totally drain it also disconnect the radiator hose. not 100% on that, but it's worth taking a look
Old Jan 24, 2008 | 03:05 PM
Edubs's Avatar
http://tunersource.gmblogs.com/Racer...LSJ_Chap_2.pdf
Pages 4 and 5...
Old Jan 24, 2008 | 03:06 PM
celicacobalt's Avatar
when should the coolant be changed? i thought it was good for 100,000 miles
Old Jan 24, 2008 | 03:08 PM
Edubs's Avatar
Mkulrey13 is putting a Garrett turbo kit on his car. I'm guessing he's pulling the engine bay apart to prepare for the installation. Not sure why he needs to dissassemble the cooling system, but I'm guessing there's a valid reason...
Old Jan 24, 2008 | 08:56 PM
mkulrey13's Avatar
Well yes and no, i DO need to drain the coolent to install my turbokit adn the turbo is oil AND water cooled. But im doing it to install my water temp sender in the hose. Saves me a few bucks from the shop whos doing the install for me on the turbo.
Im installing a adapter in the upper hose, would it hurt to pinch of an area and cut between the pinched areas and install my adatper? do i have to worry about bubbles in teh system or will they work them selfs out?
bump!
Old Jan 24, 2008 | 09:02 PM
Sunburst_SS's Avatar
COOLANT!!!! not coolent lol
Anyway, the fastest way is probably to just remove the lower radiator hose and let it drain into a pan. Take the cap off the coolant jug and it'll drain a little quicker.
Also, the system will bleed it self out. After you're finished, bring the car up to operating temperature, rev. it up to around 2500 rpm a few times, then shut the car off and let it cool down. The air bubbles should work them selves out after a couple times heating up and cooling off.
Old Jan 24, 2008 | 11:05 PM
mkulrey13's Avatar
Can i jsut pinch teh upper hose? cut and insert my adapter and seal back up? i really dont wanna drain my system
Old Jan 25, 2008 | 12:53 AM
tricky1's Avatar
thats how i did mine, cept i put it in the wrong hose. just make sure you replace the lost coolant. Oh yes, there WILL be COOLANT!...lol
Old Jan 25, 2008 | 05:58 PM
mkulrey13's Avatar
haah wow sp i spelled COOLANT WRONG big deal
Old Jan 25, 2008 | 07:54 PM
Thats crazy there is no how to on changing the coolant...
Old Jan 25, 2008 | 08:06 PM
there should be a petcock on the right-hand side (passanger) of the radiator......jack up the car, put a drain pan under the plug...open it and drain. Be sure to have the cap off the coolant jug when doing it, it'll drain faster.
here's a pic....look for that little plug on the bottom right
Old Jan 27, 2008 | 07:07 PM
are you sure there is a plug there? i would like to try to utilze this tomorrow if this is true.
Old Jan 27, 2008 | 07:55 PM
shoud be......I haven't looked on my car.....I pulled that picture off Dealerworld for you to see. Pretty sure it will be there
Old Jan 27, 2008 | 08:11 PM
good info here:
Originally Posted by Kaisoboy
Here yah go.
hope this helps
Old Jan 27, 2008 | 08:27 PM
yes, if you want to drain the coolant from the block also, you will want to open the plug on the bottom of the water pump. For what you want to do, you will be fine with just draining through the radiator
Old Jan 27, 2008 | 08:29 PM
can i use my tap water for the 50/50 mix? or do i have to use distilled water. in the manual it says just water safe for drinking...
Old Jan 27, 2008 | 08:32 PM
yea, they say that becuase if you have some dirty water come out of the hose bib and then put that in the radiator, it could clog up the cooling system.
Old Jan 27, 2008 | 08:34 PM
DebadgedBALT77's Avatar
you can use tap celica. we use it all the time at work.
Old Jan 27, 2008 | 08:46 PM
sounds good. i just got done running the car with the coolant cap off for 5 minutes to see if any air bubbles might come out as someone on here suggested. tomorrow im gonna drain and refill with new dexcool and watter wetter.
Old Jan 28, 2008 | 07:51 PM
cant seem to find a petcock like the one that was posted in the drawing. the pictured area i found but i cant figure out how to remove the valve to drain the coolant, i cant see any hoses either cuz my intercooler is in the way.
Old Jan 28, 2008 | 08:52 PM
montecarloman's Avatar
You can use regular water but I highly recommend distilled water. Tap water with all the minerals in it can and will lead to electrolysis within the cooling system.
Old Feb 22, 2008 | 07:22 PM
blkSSgirl's Avatar
So theres not a bleed valve?
Old Feb 22, 2008 | 08:32 PM
no.....that's pretty much why the coolant just has a vent tube, to bleed off pressure/air
hacadacalopolis
Oct 28, 2015 06:09 PM
EvlPeanut
Dec 30, 2007 06:26 PM
mkulrey13
Jul 29, 2007 07:59 PM
yellowshowbalt
May 27, 2007 08:16 PM
Cyrus the Virus
Mar 13, 2006 08:58 PM
