09 SS/TC intake & tune question
Old May 8, 2015 | 12:21 PM
Cristo SS/TC's Avatar
Hi All. So I got my 09 SS/TC back about 3 wks ago. Had an LDK from ZZP put in due to a porous block. Only had 34k on LNF. It has just over 1200 miles, did oil change at 1000k. After reading through a ton of threads on intakes and tunes, I have decided I want to do the ZZP intake tube/airbox mod and ZZP canned tune.
My question is. I did the airbox mod and added a Spectre air filter, however I have not purchased the ZZP intake tube yet. When I get the tube, do I need to get the tune right away?
Also, It doesn't seem to pull as hard as the LNF did. Does it need more mileage before its fully broken in?
BTW, I only had the car for 3 wks before it went in for the swap. 4 months later battling with warranty and dealer I got it back. So all this is still new to me.
Thanks, Mike
Old May 8, 2015 | 12:47 PM
ATOMbomb's Avatar
I would assume that you don't need the tune right away. I have a cai no tune. You just won't get any gains and your afr will be skwed. As far as the ldk, I have no clue about the pulls but breaking in should be around 1500 miles I believe.
Old May 8, 2015 | 12:50 PM
Sl0wbaltSS's Avatar
You should get the K&N typhoon intake with a catless dp the get their tune.
Old May 8, 2015 | 12:54 PM
I would like to do a catless DP, but I live in Cali and will not pass Smog ck.
Old May 8, 2015 | 09:56 PM
sixgear's Avatar
Thanks, Mike
What issues did you experience and come to the porus block conclusion?
Old May 8, 2015 | 11:47 PM
09outlander's Avatar
Please tell me you aren't doing pulls on a new motor.
Old May 9, 2015 | 12:10 AM
Superbolt's Avatar
Really tho ya got to break that engine in right.
Old May 9, 2015 | 01:54 AM
Getaway_Driver's Avatar
Your engine went to **** within 34k miles? Damn. Talk about shitty luck.
Old May 9, 2015 | 11:07 AM
tomj77's Avatar
My first engine went to **** due to porus block after 2k kms
Old May 11, 2015 | 02:22 AM
Not till after I hit 1200 miles and no wot pulls.
Old May 11, 2015 | 02:24 AM
Car drank 1 gal of coolant in 2 wks. No leaks.
lendsley
Sep 22, 2015 10:48 PM
dennis69
Sep 22, 2015 08:56 AM
dennis69
Sep 21, 2015 11:55 AM
ashalle2
Sep 16, 2015 10:36 PM
