2009 shifter linkage upgrade
Old Jun 7, 2024 | 06:44 PM
TulsaMat's Avatar
I was hoping to tighten up my shifter with a new shifter assembly for 2009 SS TC sedan. 150k miles. the part is discontinued. I went ahead and got the 15257212 part number for the M86 trans bc I saw someone say its much better but takes a little modification. Anyone done these modifications?? Would love to hear about it.
Old Jun 7, 2024 | 08:01 PM
blu3_v1p3r's Avatar
So I don't know what exactly you are looking for, but OTTP makes everything you need to make tighten it up. They make solid base bushings, a new pivot cup for, and upgraded cable clamps. They also offer one of the best short shifter you can find.
Shifter
https://www.overthetopperformance.co...-F35_p_15.html
Base Bushings
https://www.overthetopperformance.co...ngs-_p_78.html
Bottom Cable Clamp
https://www.overthetopperformance.co...ottom_p_7.html
Side Cable Clamp
https://www.overthetopperformance.co...-Side_p_8.html
Pivot Cup
https://www.overthetopperformance.co...F35_p_272.html
Old Jun 7, 2024 | 11:26 PM
TulsaMat's Avatar
Good info, but since I have the other shifter version, I was hoping to hear what's required to make it fit. I'm fine with it not being a short shifter.
Old Jun 8, 2024 | 07:57 PM
blu3_v1p3r's Avatar
The one you purchased is for the M86, which is the Cobalt with the F23 manual transmission. I think to use that you need to buy the F23 shifter, and even then I don't think if that shifter is compatible with the LNF F35 shifter cables. I do know for sure that the F23 shifter cables are not compatible with the LNF F35 transmission. To use that shifter box you would either have to modify the pivot cup to allow the F35 shifter to fit, or use the F23 transmission, F23 clutch, F23 transmission mounts, f23 shifter cables, and he F23 shifter. If I was in your shoes I would buy the replacement pivot cup and solid base bushings from OTTP and use the original shifter box. the replacement pivot cup really does bring it back to life.
LyellT
Oct 21, 2021 01:15 PM
71jcguy
Jun 28, 2019 08:53 AM
MurderMittenSS
Jan 19, 2015 08:51 PM
SilverSS/SC
Jan 31, 2006 04:01 PM
