2nd gear issues
Old Jun 6, 2010 | 01:18 PM
fredds-turbaltSS's Avatar
2nd gear issues
ok so a notice downshifting from 3-2 it grinds sometimes, the clutch is deff fully down when it happens. has anyone had an issue like this? also i notice latly its hard to get into first i usually will have to try putting it into 2nd or 3rd befor i can just put it into first if that has anything to do with it.
Old Jun 6, 2010 | 04:47 PM
RYRO14's Avatar
sounds like a synchro.
Old Jun 6, 2010 | 04:50 PM
ssyeller's Avatar
could be air in the clutch MCylinder.
New clutch or other work on same?
Old Jun 7, 2010 | 05:43 PM
mkriebs's Avatar
Try changing the fluid. But keep the OEM fluid in there. I tried redline, and I think its time for a synchro. Def not worth ruining the trans to save $20 on fluid.
Old Jun 7, 2010 | 05:46 PM
blk06cbltss's Avatar
just had this happen to me i thought it was the slave cylinder or the clutch master cylinder but the dealer said its the ball in the shifter and i read a few people had that problem so a short throw just might fix it
Old Jun 7, 2010 | 06:10 PM
tom.g's Avatar
Do you blip the throttle when you downshift? If you rev match and your still having issues getting into gear you've got a problem.
Old Jun 7, 2010 | 06:11 PM
blackss2.0's Avatar
I just had this problem. Roll pin was sheared off and caused some other problems. Service manager just called me to tell me they're giving me a new transmission.
Old Jun 7, 2010 | 06:13 PM
i have even tried clutchless shifting and i still couldnt find the gears but im not worried about anything because of my warrenty
Old Jun 7, 2010 | 06:28 PM
BYT*SS*TURBO's Avatar
Mine just started doing this occasionally! I thought it was just because I have a lil too much fun. Ill have to check the pins on the tranny portion then check the cup pieces again. I already broke one, wouldnt surprise me to have broken another.
Old Jun 7, 2010 | 06:36 PM
Ahhh information i like itt
Old Jun 7, 2010 | 06:41 PM
there needs to be a recall on this. it seems to be a problem
Old Jun 7, 2010 | 06:42 PM
the connections to the bottom of my shifter is fine, i just broke the one on the bottom of the shifter ball but replaced it and it did the a few times befor that happened anyway. ill have to check out the connections to the transmission itself i guess maybe that broke or something.
these trannys dont handle that much power to begin with
Last edited by fredds-turbaltSS; Jun 7, 2010 at 06:42 PM. Reason: Automerged Doublepost
Old Jun 7, 2010 | 06:46 PM
just try to baby it because if not it will go completely limp and not want to do ****. you could try adjusting the cable on the left, that might help
Old Jun 7, 2010 | 06:55 PM
yeahhh know i am. if i cant get it by adjusting the cables, which i actually have another set from mezz's auto swap, by the weekend its going to the dealer next week
Old Jun 7, 2010 | 07:01 PM
Berto09ss's Avatar
i usually rev match when i down shift so try that...but when i shift from 4-5 it grinds a lil,this happens once in a great while though
Old Jun 7, 2010 | 07:03 PM
honda shifter ^^^^ haha
Old Jun 7, 2010 | 07:09 PM
i always rev match well maybe not always but, and its only into 2nd for the most part downshifting
\so i been avoiding that
Old Jun 7, 2010 | 08:01 PM
imacho2's Avatar
i have this on my '01 cav. i tried replacing the clutch. didnt help. my mechanic said the synchros are worn and need to be replaced.
Old Jun 8, 2010 | 05:26 PM
byt any feedback?
Old Jun 8, 2010 | 06:00 PM
I had replace the 1 piece on the bottom of the shifter already, wouldnt surprise me to find something else broken lol.
Old Jun 8, 2010 | 06:42 PM
just got it back from the dealer it was the roll pin, i guess the roll pin sheaded off at the tranny. sad thing was the dealer was like it wont go into 5th or revers so i had to show them how to adjust the cables haha. gotta love them chevy dealers. they tried telln me i needed all new linkage and a shifter til i told them id do it myself then they just fixed it haha.
Old Jun 8, 2010 | 06:51 PM
Nice!! Ill have to check mine out then
Old Jun 8, 2010 | 06:57 PM
JoeBMX's Avatar
Fixed under warranty?
Old Jun 8, 2010 | 07:14 PM
haha warrenty i wish. its an 06 with 75k no warrenty =( fixed outa my wallet lol
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
