5000km, brakes.
Old Mar 25, 2009 | 03:13 PM
malachii's Avatar
5000km, brakes.
Guys, I've noticed that my brakes are "pulsing" when coming to a stop already. i've only got 5000km on the car. This is odd. I don't race the car, but I don't baby it either. Is this a warped rotor for sure? I noticed that the rear rotors both have fairly deep gouges in them. The front ones seem fine. Anybody else have this?
Mal.
Old Mar 25, 2009 | 05:36 PM
J.U. 996SPS's Avatar
They have a service bulletin to install Saab brake pads on the rear....
Check the torque on your wheels, over tightened lugs can cause warping.
Old Mar 25, 2009 | 05:38 PM
G Speed's Avatar
the saab brake pads are the cobalt ss/tc brakes pads.. they are the same...
Old Mar 25, 2009 | 05:40 PM
1WhiteSSTC's Avatar
Mal.
i have about 14,000KM on mine, so far my brakes are good, and I've been HARD on them a few times too. Your rear rotors will likely always look that way, it's the pad that was used, i've often thought about trying a softer compound on the rear but I also don't want to give up braking power.
Old Mar 25, 2009 | 05:43 PM
The rear brake calipers are off of a Saab 9-3. The pads are something different. Saab uses very soft pads, hence the brake dust
Old Mar 26, 2009 | 11:17 AM
malachii's Avatar
I'll check the torque, but I torqued them to (if memory serves) about 80 pounds when installing my winters, so I don't think that is it, unless the dealer removed the rims and torqued them too tight.
I wonder if putting my summers back on (and re-torquing on the summer rims) might "unbend" the rotors.
So anyhow, I never got an answer- do you have scoring in your rear rotors (notable)?
Mal.
Old Mar 26, 2009 | 12:18 PM
Force's Avatar
Mal.
GM recommends 100ft/lb when you torque the lugs, just FYI. I'd torque them to that level when you re-install the summers.
Old Mar 26, 2009 | 12:22 PM
umrdyldo's Avatar
Mal.
I had this discussion yesterday in fact. A friend of mine is going through tech school for ASE or whatever. He said a major cause of warping is under or over tightening the lugs. I'd retighten the lugs to 100ft lbs and be soft on the brakes for a bit and see if it clears.
Cobalt08LS
Jun 19, 2016 07:29 PM
Delta coupe
Jun 3, 2007 11:47 PM
GilSS
May 11, 2007 12:16 AM
06G5GT
Aug 3, 2006 12:09 AM
trebass
Mar 29, 2006 12:12 AM
