Bnr k04-gt28
Old Apr 20, 2011 | 03:54 PM
  #1451
Stamina's Avatar
Originally Posted by HHRSSouth
[...] I tried the 11 psi spring and 10 psi spring hooked up to direct vacuum source, with a 1/4" ID line on the intake manifold and it sucked imo.
Drewbroo told me to do the solenoid method. [...] Waaaay better.
Originally Posted by BYT*SS*TURBO
[...] I would run it directly to vacuum and remove the BPV solenoid.
LOL... poor Cuban... conflicting messages.
Hey man, whatever route you decide on going, I can help you make it happen and get it hooked up right.
Old Apr 20, 2011 | 04:04 PM
  #1452
cubaniche's Avatar
LOL Okay guys. I apreciate it Stamina!
Old Apr 20, 2011 | 04:48 PM
  #1453
FF_ace's Avatar
The vaccum off the to of the manifold I teed off a94 connected my bov to
Old Apr 20, 2011 | 04:50 PM
  #1454
HHRSSouth's Avatar
Well if BYT can't tune with the BOV hooked up to the solenoid, then you probably need to hook it up to direct vacuum.
Since BYT is your tuner.
But if you ever get sick of the turkey call (flutter/surge) and slow reaction time, give the solenoid/BPV method with 6 or 8psi spring a try.
I think you will be pleasntly surprised.
Old Apr 20, 2011 | 09:39 PM
  #1455
drewbroo's Avatar
I don't remember telling anyone any of this
Old Apr 20, 2011 | 09:49 PM
  #1456
drewbroo's Avatar
I still get flutter at under 15 PSI with the 8 PSI spring. I got rid of it then it came back with the new engine.
Old Apr 20, 2011 | 10:00 PM
  #1457
HHRSSouth's Avatar
Wonder why it re-appeared its ugly face?
From what I read on the world wide web, partial boost flutter is not detremental to turbo failure, partial boost flutter is normal from what I've seen posted.
Flutter at WOT or any kind of turbo surge is bad ju ju.
Old Apr 21, 2011 | 08:57 AM
  #1458
BYT*SS*TURBO's Avatar
Why can't I tune it with it hooked up to the solenoid? lol.. That has nothing to do with anything..
I prefer on the bigger turbo cars that it works mechanical, IMO, it works better that way. If you like yours on the solenoid, then leave it. Mike can make his own choice on what he likes also. Doesn't really matter in the end, it's a non issue.
Old Apr 21, 2011 | 09:28 AM
  #1459
drewbroo's Avatar
yeah the flutter isnt surge, surge is a bad thing.
Old Apr 21, 2011 | 10:52 AM
  #1460
Sweetsandman's Avatar
Flutter =/= Surge
Surge is bad. Flutter, not so much.
This is Surge:
YouTube - True Compressor Surge
If you are not experiencing that, you're fine.
Old Apr 21, 2011 | 10:59 AM
  #1461
PBass is also exchanging his 2860 for a 2871 now. Bryan didn't seem too happy that Mike's success was getting around to other people. Eventho he admitted finally that its a fail on this car.
Old Apr 21, 2011 | 11:53 AM
  #1462
cubaniche's Avatar
Oh no really? lol I thought thats what he was going to do for both of us.
Old Apr 21, 2011 | 06:14 PM
  #1463
drewbroo's Avatar
Do they do a 2876 at all?
Old Apr 21, 2011 | 06:18 PM
  #1464
elecblue06's Avatar
a 2876 or 3076 a 3076 would make for a nice stg 2 i think have the 2871 as the stg 1
  #1465
vahdyx's Avatar
YouTube - Compressor Surge Demo
I thought this wowowowowow noise was surge
Old Apr 21, 2011 | 06:43 PM
  #1466
elecblue06's Avatar
that sounds like an incorrectly adjusted BOV
Old Apr 21, 2011 | 07:38 PM
  #1467
vahdyx's Avatar
So it'll be more like this then?
So surge is during spool up, not release of pressure. The wowowow during release is just blow off flutter?
If this is true, then Dejon was right about their spring not creating surge, it creates flutter. Man was I wrong then.
YouTube - Compressor Surge - Grand National
Old Apr 21, 2011 | 07:51 PM
  #1468
elecblue06's Avatar
yea surge is under extra pressure .. if it's happening when it's blowing off somethings just not setup right
least to my understanding
Old Apr 21, 2011 | 10:31 PM
  #1469
Matt M's Avatar
They are both surge. Surge happens any time there is not enough energy driving the exhaust wheel to overcome the back-pressure against the compressor wheel. This means it can happen when the turbo is too big for the motor making the boost pressure very high because the motor just does not flow well enough. It can happen when the exhaust wheel is too small in relation to the compressor wheel. It can also happen when the charge tubes and intercooler are already pressurized and you let off the throttle. Exhaust pressure drops suddenly and the pressure in the charge tubes/turbo stops the compressor wheel or slows it down very quickly. Bypass valves and blow-off valves are utilized to eliminate this type of surge.
Old Apr 21, 2011 | 10:48 PM
  #1470
elecblue06's Avatar
i had the issue on my car when procharged .. when the BOV wasn't adjusted correctly as well when i was turboed and not correctly adjusted so thats what i was going off
Old Apr 22, 2011 | 01:56 AM
  #1471
08ssedan's Avatar
TGLEMS: 12.9 @ 117
Old Apr 22, 2011 | 08:16 AM
  #1472
HHRSSouth's Avatar
Damn did that other car jump or did tglem take off late?
Either way tglem almost beat the guy to the end of the finish even after the late start (or early jump by other guy).
Old Apr 22, 2011 | 09:34 AM
  #1473
cubaniche's Avatar
LOL WOW
117 is nice trap. You need a set of slicks my friend
Old Apr 22, 2011 | 11:49 AM
  #1474
dandaman15's Avatar
He did beat the other guy and if you look at the tree the other guy gets the countdown first.
Old Apr 22, 2011 | 03:03 PM
  #1475
tglems's Avatar
Yeah, that was bracket racing and I was racing a Z4. I don't know what he was dialed in at, but he definitely had the start before me. But yeah, I won and moved on to the next round. I was happy with the 12.9, but if I had slick I'd be low 12's, maybe even flirting with 11's...
