Bnr k04-gt28
Old May 2, 2011 | 02:28 PM
  #1526
Terminator2's Avatar
Originally Posted by Iam Broke
Damn, I'm not where I can access HPT, but there is a big difference in one of the boost table axis between the two base files, one tops out at 17.x psi, while the other is around 23. Raise that sucker to 25 or so in the last column axis. One of the boost controller tables, top scale axis. Damn... I forget too much ****.
Maybe you are getting so far out of range it's shutting it down.
I had two 91 octane files for him. He originally had the factory sensors when I first tuned him on the stock turbo then he upgraded to the 3 bar sensors. I accidentally sent him the factory sensor file which he did a write entire on the get rid of the trifecta underlay. I realized what happened and sent him the correct file but he needs to do a write entire with it to correct for the map sensor scaling and torque scaling. He already tried a write calibration and no change. I believe this is the whole issue. I hope that is all it is. Crosses fingers.
Old May 2, 2011 | 02:34 PM
  #1527
drewbroo's Avatar
We will see this afternoon when I get home. I think its the intake collapse. The elbow on the CIA Sri seems weak. A collapse would cause a super rich condition for a split second. I did a write entire this morning with the 3 Bar file. We will see I guess. I don't mind trouble shooting, I like learning new things.
I've also had the MAF freq limp me out over ~12,000 hz. Bigger diameter MAF cross section would fix that.
Also I am getting no codes
Old May 2, 2011 | 02:36 PM
  #1528
Yep MAF max delta is approx 12K Hz. Drew"s car hits around 11,300 Hz max on the stock turbo.
Old May 2, 2011 | 02:43 PM
  #1529
RyRidesMotox's Avatar
I didn't get a code when I relocated my maf, it just timing or whatever and sounded like butthole... but luckily term is a magical beast bent on world domination, he fixed it up with the quickness.
  #1530
drewbroo's Avatar
its the MAF relocate....
Old May 2, 2011 | 02:48 PM
  #1531
Iam Broke's Avatar
I don't remember getting any codes when my MAF freq spiked and limped me, but that was last year. I forgetz. It was when the intake was sucking water & I saw 13k HZ spikes on occasion with a MAF relocate to the cold CP.
I found a post on HPT of the table I was talking about above, Proportional Max, Desired Boost axis.
If the 3 bar file doesn't do it, ramp that scaling up to what you see for boost.
I understand that first hand, and gave it up.
Old May 2, 2011 | 02:51 PM
  #1532
Hmm you already did a write entire with the 3 bar file that makes me suspect the intake elbow as well. Normally all you need to do is the regular write calibration with the tune files from now on.
Old May 2, 2011 | 03:00 PM
  #1533
drewbroo's Avatar
I am gonna try the intake elbow when I get off work today. I was almost able to squeeze it shut with my hands where it connects at the turbo. The stock turbo was flowing 30lbs VE on the last setup. The new turbo hits that much more violently at a lower RPM. So step 1: Change the intake coupler. See where that gets me.
Theorethically I can run open turbo intake side since I have the maf relocate anyways. That will be a quick check for collapse.
Old May 2, 2011 | 03:08 PM
  #1534
Iam Broke's Avatar
Just don't suck a toad in there. lol.
Old May 2, 2011 | 03:10 PM
  #1535
drewbroo's Avatar
its just going to be for a short run down the street. Hopefully no birds fly in there. I might just throw a stock AB on just to be safe.
Old May 2, 2011 | 03:11 PM
  #1536
Yep you dont need an intake on your turbo just a filter to keep debris out really LOL.
Old May 2, 2011 | 03:13 PM
  #1537
Iam Broke's Avatar
At least a short coupler to help guide air into the turbo, I'm afraid it might cavitate without some straightening of the airflow. Term knows better than I.
Old May 2, 2011 | 03:21 PM
  #1538
drewbroo's Avatar
Also one thing I noticed about the BNR2871, the intake side where you connect the intake to is smaller than on the K04. This might be why I am getting collapse. It might be creating a "pinch" in the coupler.
Old May 2, 2011 | 03:25 PM
  #1539
ROTFLMFAO. I had the intake off my 99 Dakota RT back when I first started driving. I was putting JBA shorty headers on. The next morning I put the truck back together and drove it. The throttle stuck nearly wide open. I was like WTF is wrong. I took the intake off and looked at the throttle body and there was a big ass toad stuck in the throttle body. His legs and ass were hanging out. He was smashed up badly but still alive. I will never forget that day for the rest of my life.
Old May 2, 2011 | 03:28 PM
  #1540
You would think the intake would larger on the 2871 not smaller.
Old May 2, 2011 | 03:33 PM
  #1541
It should be ok at WOT. Part throttle might be a little airflow disturbance.
Old May 2, 2011 | 05:02 PM
  #1542
drewbroo's Avatar
I picked up a steel 2 1/2 -> 2 1/4 reducer. I am going to bullet proof it from flex. The inlet on the BNR 2871 seems to be a 2 1/4 not a 2.5.
Old May 2, 2011 | 05:14 PM
  #1543
elecblue06's Avatar
really? from what it looked like with mine it looked like it was at least the same size
Old May 2, 2011 | 05:36 PM
  #1544
drewbroo's Avatar
Its slightly smaller, I had it sitting right next to my K04, looks wise is close, but its a 1/4'' smaller.
Old May 2, 2011 | 05:54 PM
  #1545
elecblue06's Avatar
thats weird considering how much larger the compressor wheel is lol i'll take your word for it .. i have one on the car and the other in the trunk in the package
Old May 2, 2011 | 06:17 PM
  #1546
Iam Broke's Avatar
Glad I sparked a funny memory. That's a good one.
Old May 2, 2011 | 06:26 PM
  #1547
drewbroo's Avatar
Yeah I figured it out when my coupler wasn't tight on the turbo intake. The coupler has a clear bulge on it with the new turbo.
Old May 2, 2011 | 06:47 PM
  #1548
elecblue06's Avatar
good to know for when i get my intake made lol
Old May 2, 2011 | 09:37 PM
  #1549
drewbroo's Avatar
I mjade a franken intake, and it fixed it. So yeah it was the intake collapsing
Old May 2, 2011 | 09:39 PM
  #1550
Iam Broke's Avatar
Pix or it didn't happen.
