Brakes under warranty?
Old Jul 24, 2012 | 12:14 PM
jgerma01's Avatar
Well im going to dealership tomorrow to see if they can fix the parking brake problem I am having (brake will not hold car). I was doing searches on rear brake problems and it seems I am having the same problem where the inner pad on the rear brakes is worn all the way down and the outer pad looks almost new.
My question is there a service bulletin on the rear brake issue for a 2010 SS? I couldnt find it after searching on here and was just wondering if anyone had it so that I can at least give it to the dealer because I am positive they are going to give me **** about fixing this under warranty, still have 11,000 miles left on my bumper to bumper
Old Jul 24, 2012 | 12:19 PM
theamericanautos's Avatar
should be fixed under warranty. I had the same issue and I wasn't charged
Old Jul 24, 2012 | 12:23 PM
umrdyldo's Avatar
Depends on the dealer.
Brakes are a wear item and covered to 12k miles.
Now, this should be covered under 36k because the abnormal wear is causing a safety issue.
Old Jul 24, 2012 | 02:46 PM
094doorSS/TC's Avatar
Most dealer's are not going to do anything about it. What i would do is ask them for expiation on why the pads are warm on the inside and fine on the outside, then say I've never own a car that needed rear brakes at 25K, and needed rear brakes before the front brakes witch do 80% of the stopping.
Old Jul 25, 2012 | 12:31 AM
kzak104's Avatar
if you mean the e brake, they should adjust it under warranty, they did mine because i was to lazy to :P
Old Jul 25, 2012 | 01:48 AM
jgerma01's Avatar
Yea i have adjusted the ebrake once already which worked for about a month or two, was able to hold the car in 3 to 5 clicks.....now back the way it was which has me thinking one of the rear calipers is hung up or something
Old Jul 25, 2012 | 02:27 PM
SSlobalt's Avatar
It most likely is.
Old Jul 25, 2012 | 03:05 PM
Macgyver2484's Avatar
Have you lubed the caliper pins? That can cause uneven pad wear.
Old Jul 25, 2012 | 04:03 PM
Cobalt_Daddy's Avatar
they will replace it under warranty... i had new pads and rotors at 36,000km. if the dealer says no.. go to another dealership.
Old Jul 25, 2012 | 04:06 PM
MoJoJoSSsc03's Avatar
my driver side back rotor ended up wearing out waay before all my other and my ebrake wouldn hold my car either, and my driveway is a good size incline, sooo a mechanic ended up fixin mine cuz i was at like 80k miles... but im sure they can fix ebrake cuz of safety issues under warranty
Old Jul 26, 2012 | 02:05 PM
jgerma01's Avatar
Well brought car to dealership, they claim rear pads are wearing normally and have a decent amount of life left, they adjusted the ebrake cable which i had already done and feel is a temporary fix.
They also say I need front pads and rotors after 25,000 miles which is understandable, at the same time they want $660 plus tax to do them at which point I left lol.
Old Aug 6, 2012 | 07:07 PM
Jaramie3's Avatar
Ive had my Cobalt ss/tc since november 2008 and my front pads are perfectly fine. My car just turned over 59,000 miles. The rear pads went at around 14k which gm refused to replace them for free.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
importkiller
Sep 30, 2015 07:18 PM
