Charge Piping Came Loose.....
Old Mar 6, 2009 | 04:12 PM
  #51
TrevMo's Avatar
Originally Posted by metroplex
There's a TSB for this on 08-09 SS/TC Cobalts...
My Dad just ran my VIN and he said there is nothing out for my car right now...I have an 08 that was built in April of 2008...
Old Mar 12, 2009 | 07:44 AM
  #52
metroplex's Avatar
Sure thing:
Make : CHEVROLET Model : COBALT SS Year : 2008
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Number : PIP-4485 Date of Bulletin : OCT 01, 2008
NHTSA Item Number : 10026690
Component : ENGINE AND ENGINE COOLING:COOLING SYSTEM:RADIATOR ASSEMBLY
Summary :
GMC: LOW BOOST, REDUCED POWER AND/OR DTC ON CERTAIN 2008-09 COBALT SS. INSPECT THE RIGHT SIDE CAC (CHARGE AIR COOLER) PIPE FOR CONTACT ON RADIATOR SUPPORT BOLT. *PE
Check to Request Research. Submit below.
Component : ENGINE AND ENGINE COOLING:COOLING SYSTEM:HOSE
Summary :
Service Bulletin Number : 08-200 Date of Bulletin : JUN 01, 2008
NHTSA Item Number : 10026606
Component : ENGINE AND ENGINE COOLING:ENGINE
Summary :
GMC: ENGINE OIL PAN DRAIN PLUG THREAD INSERT LOOSE OR DAMAGED-INSPECT/INSTALL NEW INSERT. VEHICLES MAY HAVE AN UNDERSIZE ENGINE OIL PAN DRAIN PLUG THREAD INSERT THAT WILL BE INSTALLED TOO FAR INTO THE OIL PAN HOLE. *PE CSC LETTER WAS RECEIVED. UPDATED 12/1/08. *PE
Here it is for 2009:
I realize they're just repeats, but I wanted to post everything I got off the NHTSA site:
Make : CHEVROLET Model : COBALT SS Year : 2009
Summary :
Summary :
Old Mar 12, 2009 | 03:25 PM
  #53
streat screamer's Avatar
Unhappy better fix it!
my bracket broke and the piping shifted in the engine bay and got smashed between my engine and the hood. I already had bsr/ppc,hahn 3",and hahn cold air intake, so i figured it was a perfect excuse to get the hahn piping. Installed and drove the car, about 50 miles later the engine light comes on. so i end up replacing the MAF sensor,& MAP sensor (first one in the contry)and buy a scanner to reset computer. Car seems to run fine again for about 50 miles till the light comes on again. Missfire codes everywhere.
So i take the tune out of the car, change the plugs drive about 50 miles not only do iget miss-fire codes but i get a U0073 code that i dont what the hell means. So I start to take it back to stock and discover oil in my turbo. Did i just discover my problem or a catastrify? And what is the next step?!?
Old Mar 13, 2009 | 02:16 PM
  #54
metroplex's Avatar
I looked at a 09 SS/TC at a dealership. The charge air pipe fell out of the "stud" and the salesperson didn't know anything about a TSB (PIP-4485). I wasn't sure if it was a bolt or stud, but I popped it back into place. It seemed like they changed it into a rubber grommet so that it would just clip onto a stud. That looks like a problem down the road. Has anyone found a sure-fire fix for this? I popped it back into place in front of the salesperson.
Nonetheless, the plastic charge air tube was STILL rubbing against the A/C line. Any ideas?
Old Mar 13, 2009 | 05:03 PM
  #55
1WhiteSSTC's Avatar
did u completely miss page one of this thread??? zip ties are the fix man, GM won't do *** all about it so either get better charge piping or suck it up and zip tie it.
Old Mar 13, 2009 | 05:06 PM
  #56
metroplex's Avatar
I saw the pics but that still doesn't move the air tube away from the A/C line. The one at the dealer was rubbing that line badly even after I moved it back into place.
Is there an aftermarket pipe available that clears everything?
It seems odd that I had to fix a new car at the dealership in front of the sales person.
Have you checked to see what is involved with the TSB? GM obviously knows about it, otherwise they wouldn't have assigned a case/number.
Old Mar 13, 2009 | 05:09 PM
  #57
widowedeight's Avatar
Originally Posted by OneCOLDBIZL272
mines on 20-21LBS of boost and i dont have this problem at all, tighten the t-blot clamps if you you this problem again, if you keep having this problem i reccommend that you invest in harndened charge pipe with bead rolled lips. note my pipes are stock at the momment but i dont have this problem, and the cars well over broken in, in mileage, guess i just got lucky and got one of the ten that were built right.....lol sorry GM
yeah i am at 24500 miles and haven't had this problem yet either....
Old Mar 13, 2009 | 05:11 PM
  #58
metroplex's Avatar
Is the paint on your door (near the lower part of the A-pillar area) still intact? I'm just curious if there is a correlation between the Cobalts with properly attached air tubes and other defects.
Old Mar 13, 2009 | 05:19 PM
  #59
1WhiteSSTC's Avatar
it's moved far enough away and secured with zip ties to prevent it from ever touching the AC lines anymore, several members on here have my ziptie mod and have never had any issues since doing it.
Old Mar 13, 2009 | 09:59 PM
  #60
Highbeamz's Avatar
If you use black zip-ties you might not even notice they're there...
Old Mar 14, 2009 | 05:26 AM
  #61
metroplex's Avatar
When I repositioned the pipe, it was still jammed against the A/C line. I don't see how the zip-tie would have solved that issue on this particular car.
Old Apr 20, 2009 | 11:03 PM
  #62
09CobaltSS1's Avatar
Angry
only 1300 miles on my 09 and mine just broke. freakin p.o.s. charge pipe
Old Apr 21, 2009 | 05:43 PM
  #63
metroplex's Avatar
Here's a pic of the stock clip on my 09 SS/TC:
Is this what everyone gets from the factory?
Old Apr 21, 2009 | 05:49 PM
  #64
2ndWhiteSSTC's Avatar
that look slightly different from mine, it appears that yours has an extra piece that would keep it clipped in, maybe it's the piece that was on mine and fell off........all i know is wat i posted in the original pics on page 1, there is a way to make it work and unless i'm standing right there i can't point it out any better than my pics. FYI, u can't use a 2inch ziptie, u need like a 3-5inch ziptie if u intend to get it attached to anything solid.
Old Apr 21, 2009 | 05:53 PM
  #65
metroplex's Avatar
I noticed the 09 SS/TC's in the lot didn't have this clip or the rubber insulator for the fuel injection pump.
Old Apr 21, 2009 | 05:57 PM
  #66
yea i'm not sure why GM did that, all I know is that my zip ties do wonderfully, u just need long enough ones to attach to something solid, if u still are having problems I could go back and take new pics and see if they help at all, let me know.
Old Apr 22, 2009 | 11:37 AM
  #67
Mazdaboi318's Avatar
mine just broke
Old Apr 22, 2009 | 11:39 AM
  #68
metroplex's Avatar
Yes, new pics would definitely help. I might use zip ties to reinforce it.
Old Apr 22, 2009 | 11:54 AM
  #69
Jaemon52's Avatar
I still don't know wtf they were thinking with plastic charge piping. They need to do a gm accessories thing to solve this if they don't want everyone going hahn.
Old Apr 22, 2009 | 12:36 PM
  #70
Terminator2's Avatar
If you look closely at the stock pipes you can see that AEM makes them for GM. You would think that they would be better designed and better quality.
Old Apr 22, 2009 | 12:41 PM
  #71
swazzees's Avatar
so its random if we have to zip it down on an 09???
nice
Old Apr 22, 2009 | 12:48 PM
  #72
nice
Mine never popped loose but I ended up blowing a small hole in the rubber hose coming out of the Turbo. I would get aftermarket chargepipes if you can afford them.
Old Apr 22, 2009 | 01:07 PM
  #73
RBC's Avatar
RBC
Mine broke aswell. The plastic clip on the charge piping that goes over the stud is what broke on mine so I really had to zip tie it. Mine looks more like the picture on the first page than the last picture shown, but I don't have the little rubber peace on the top. I have charge pipes ordered but if there's a TSB on it I am going to go get it fixed so I have a perfect stock part to put on if ever needed. Mines an 09 sedan.
Old Apr 22, 2009 | 01:10 PM
  #74
SilverSSedan's Avatar
ok, i look at these pics, and it looks like you have a picture of the insulator around some wieres, then you got a picture of a smooth rubber hose clamped to the intercooler, maybe i'm blind, but can someone maybe put an arrow at where were looking from one of the whole engine bay pictures...?
Old Apr 22, 2009 | 01:27 PM
  #75
This should help
