Do I need to adjust my wastegate rod?
Old Jan 12, 2012 | 11:27 PM
KissMy08SS's Avatar
Got together with Vince....and this is what he said:
"You have a problem with the turbo – more specifically its wastegate.
You just reinstalled the original GMS1 tune, and it has the same symptom. What’s happening is the turbo is slightly overboosting, then underboosting during part throttle, causing this surging effect.
It looks like the wastegate might be sticking or maybe isn’t adjusted properly. Have you messed with the wastegate adjustment on the turbo? A popular early mod to these was to adjust the wastegate actuator rod length.
We might also be able to tune it out, but that might be putting a band-aid over another problem - nobody else needs to have the WG settings messed with in their tune unless they’ve changed the turbo."
- Vince Geglia
Trifecta Performance, Inc.
Would you guys try to adjust the wastegate rod or just replace the entire wastegate actuator?
Here are a few more recent video's that I sent to Vince...like I said...this only occurs at part throttle. At WOT...runs fine...no surging, 27 lbs boost spike while Trifecta is engaged.
http://www.youtube.com/watch?v=xdgLJ...1&feature=plcp
http://www.youtube.com/watch?v=WMOCE...2&feature=plcp
http://www.youtube.com/watch?v=V0Mtr...lcp&playnext=2
Old Jan 14, 2012 | 09:38 AM
KissMy08SS's Avatar
anyone.....
Old Jan 14, 2012 | 10:48 AM
steven2008ss's Avatar
vids dont work
BUT i had the same problem, it was my sensors tho, it had oil on them, once i fixed them they stopped giving me a problem, i also through a P0106 code, and i took care of it with my friend
Last edited by steven2008ss; Jan 14, 2012 at 10:48 AM. Reason: Automerged Doublepost
Old Jan 14, 2012 | 11:33 AM
KissMy08SS's Avatar
video's are working perfect here
I know for a fact it's not the sensor's....it would have shown up in the datalog. I guess another question would be....what would cause the wastegate to open and close under part throttle? Does the wastgate actuator need adjusted?
Old Jan 14, 2012 | 03:02 PM
Yes, it could, it could be stuck open, making the car think it needs more psi for efficiency
Old Jan 20, 2012 | 06:54 PM
KissMy08SS's Avatar
Canyone tell me if I can use this vacuum pump (for brake bleeding) to test the wastgate actuator?
Someone told me to use this....just hook the vacuum line up to the wastegate actuator, pump it up, and see how many PSI it opens up at...
Does this make sense to test the wastegate actuator?
Old Jan 20, 2012 | 06:58 PM
Chevycobaltss3's Avatar
If you put the true stock file on the car without anything trifecta and it still does it. it.can be the Pid controller or the actual wastegste.. to me its the Pid controller and not the wastegate actuator. Because if its sticking it won't speraticslly jump up snd down.
Old Jan 20, 2012 | 10:44 PM
KissMy08SS's Avatar
Hey James, is the PID controller the black unit with 3 vacuum lines and an electrical connectors? (Wastegate actuator solenoid?) If it is....I've already replaced it.....still runs the same....
Old Jan 20, 2012 | 10:56 PM
Yes, that is it.... If u put gmstage one one then u can have a map sensor issue or the wastegate rod ... But u have to pyt a gmstage file on it not trifecta gmstage one.... U need the one from ure csr
Old Jan 20, 2012 | 11:33 PM
KissMy08SS's Avatar
What is "CSR"?
Old Jan 20, 2012 | 11:41 PM
Phone error lol ... Car... U need to upload Ure file u got off Ure car.
Old Jan 20, 2012 | 11:47 PM
getwicked's Avatar
Originally Posted by KissMy08SS
What is "CSR"?
Customer service rep.? Car? Drunk?
Old Jan 20, 2012 | 11:51 PM
KissMy08SS's Avatar
Lol got'cha, that makes a little more sense
So....can't I just remove the Trifecta Tune completely (leaving just the GMS1 tune)? I wonder why he did'nt make me do that anyway instead of reloading his comparable "GMS1 tune"???
Old Jan 20, 2012 | 11:56 PM
Yes upload stock gmstage one.
Old Jan 21, 2012 | 11:48 AM
rukkee's Avatar
Could the bypass valve have anything to do with it? Correct me if Im wrong but ...... Usually if the wastegate has any over/under boost problems the car will drop into mechanical boost mode ( 5psi limp deal) . Does it throw any codes?
Or maybe this thing is just way over my head and I should STFU lol ..... just tossing out ideas.
Old Jan 21, 2012 | 12:15 PM
KissMy08SS's Avatar
I'm all for idea's my guy
I inspected the stock BPV...it was fine...but to be safe..I installed a forge motorsports BPV...and still acts the same.
It has NEVER thrown any codes. Just waiting on Vince to send me my factory tune.
BTW James...if we meet up in Noblesville on the 11th....what will you be able to do you think?
Old Jan 21, 2012 | 12:21 PM
I'll log the car...... And tell u what I see.
Old Jan 21, 2012 | 02:12 PM
KissMy08SS's Avatar
Just an update-
Just installed the factory tune GMS1 file.....still acting the same...
Old Jan 21, 2012 | 02:37 PM
Here is the thing. vince can give u a file and it can still do the same thibg if the file is corrupt or if somthibg else wasn't changed back....... Do u still have a select a tune on the car?
Old Jan 21, 2012 | 02:56 PM
robk's Avatar
James ive suggested to shawn to come in and flash to car back to stock with a tech 2. Then reflash it w the gms1 tune from the tech2.
Sorta like i did back in aug before you got ahold of the car. Remeber i took out the old tune to see if it was what was causing my random misfires, and we(tech @ work) flashed the gms1 file back on and the next day to got ahold of it. And its ran fine since.
Just my .02 tho
robk
Old Jan 21, 2012 | 03:18 PM
KissMy08SS's Avatar
Just my .02 tho
robk
Hey Rob, would one of the techs do that for me at Hare? Sam Pierce will not touch my car anymore. If so....how would I go about getting it done?? Let me know....because at this point....I'm willing to try ANYTHING.
Old Jan 21, 2012 | 03:22 PM
KissMy08SS's Avatar
He sent me my stock, original GMS1 file. I loaded it back on the car...and it still surges. So...for the time being, I don't have the Trifecta tune loaded on the car at all. BUT....I'll probably reload it later just because the car runs the same...but still has alot more power with the Trifecta loaded and engaged.
Old Jan 21, 2012 | 03:26 PM
Okie dokie.
Old Jan 21, 2012 | 04:00 PM
robk's Avatar
iI dont see why not. But to be honest youll most like have to pay to have it flashed, but ill see if theyll charge you employee. The only reason why i say that is the tech that did my car has resently quit . Ill check on monday and let ya know.
robk
Old Jan 21, 2012 | 04:44 PM
KissMy08SS's Avatar
robk
That would be great man, I really appreciate it!
hacadacalopolis
Oct 28, 2015 06:09 PM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
Stuff
Oct 1, 2015 05:47 PM
