maf tuning
Old Jun 12, 2019 | 08:38 PM
Cobalt4209's Avatar
maf tuning
When i disconect the evap my stft go to -30 at idle is this normal ? Im trying to tune my fuel trims...
Old Jun 13, 2019 | 02:20 PM
Doesnt sound normal to me. No codes?
Old Jun 13, 2019 | 02:45 PM
Not normal at all.
Disconnecting the evap plug under the hood should disable the LTFT, unless you've moved your maf to the lower charge pipe without tweaking the maf tables significantly.
Also do a boost leak test with the plastic line going to the evap solenoid unplugged (one that runs back to the gas tank) and see if the solenoid has failed. I've had mine fail that way before.
Old Jun 15, 2019 | 06:51 PM
Cobalt4209's Avatar
kk im gonna try again and see what happens . I think i forgot to reset my fuel trims last time before i started ...
Old Jun 15, 2019 | 07:00 PM
When you disconnect the evap solenoid it zeros the ltft and then you only have stft
Old Jun 15, 2019 | 07:15 PM
Cobalt4209's Avatar
kk everything is good i tested it by just tuning my idle and the stfts went from -20 to - 3.1 with a few paste by % . Its raining to much to get a driving log atm . Ill have this thing dialed in tomorrow .
thanks guys
Old Jun 16, 2019 | 01:41 PM
Cobalt4209's Avatar
Well things are going good for my fuel trims but im getting 14-16 degrees advance at wot and my spark tables are set to 12 degrees , why is the timing higher then what i have set in the tables ?
Old Jun 16, 2019 | 02:49 PM
Cobalt4209's Avatar
Thumbs up
think i figured it out i set the base correction tables to 0 in the areas it was adding timing
NICOMAN
Tuning
Jun 13, 2013 02:00 AM
Rodimus_Prime
Tuning
247
Jul 30, 2012 11:56 PM
crt013189
Tuning
Oct 20, 2008 01:43 PM
jimbos'ss
Tuning
Sep 13, 2008 01:49 AM
rrutter81
Tuning
Jul 29, 2008 10:17 PM
