Need a clutch
Old Nov 2, 2010 | 09:14 PM
raynrishad's Avatar
Need a clutch
Recomendations??
Old Nov 2, 2010 | 09:37 PM
Iam Broke's Avatar
SPEC Stage 2+ here with LW flywheel. Chatters & moans a bit when cold but never slips.
ZZP Stage 4 is a good choice also.
Old Nov 2, 2010 | 09:38 PM
TurboTechRacing's Avatar
SPEC stage 2+ or 3+ are good choices. Gotta get the "+" series, or you will not be happy...
Old Nov 2, 2010 | 09:40 PM
raynrishad's Avatar
Gotta get a flywheel with those or will mine be ok to be turned and shimmed if there isnt too much heat damage? What kind of prices are we looking at? As is I can't even drive my car. The clutch is totally gone.
Old Nov 2, 2010 | 09:41 PM
Good prices on www.TurboTechRacing.com
Most use the stock flywheel, just get it resurfaced.
Old Nov 2, 2010 | 10:19 PM
Supercharged Guy's Avatar
I guess all Spec clutches are very good
Use your stock flywheel too no need to upgrade to a LW one
Old Nov 2, 2010 | 10:35 PM
turbaltss's Avatar
3+ for me and stock flywheel. great clutch
Old Nov 2, 2010 | 11:08 PM
mongorat427's Avatar
I have a new Spec Stage 2 clutch and pressure plate in the package $475 cost $559
Old Nov 2, 2010 | 11:13 PM
CrystalRedSS's Avatar
I'd go with ZZP's Stage 4 clutch.
Old Nov 3, 2010 | 07:49 PM
raynrishad's Avatar
So, any of you guys know where I can find a flywheel JUST in case I cracked it? Dealership lists it for 860$ and none of the local parts stores, napa, carquest, autozone, oreilly even lists them. I've found the lightweight aluminum ones online for around 400$
Old Nov 3, 2010 | 07:53 PM
Iam Broke's Avatar
I have my stocker I'll sell for $300 + shipping if you want it, It's a heavy beast to ship though. Make me an offer I can't refuse.
Old Nov 3, 2010 | 07:57 PM
Wangspeed's Avatar
No way you cracked the FW.
Old Nov 3, 2010 | 08:01 PM
Iam Broke's Avatar
Looks like a Stage 2+, is it? The LNF needs a 2+ for the torque.
Old Nov 3, 2010 | 09:31 PM
Its good to 495 ft lbs
Old Nov 3, 2010 | 09:33 PM
No that is not the correct part number for the 2+ it is the normal/plain 2...
SPEC states... Real life is much less IMO. That is why members should only get a "+" series, less clutch chatter and much more holding power.
Last edited by TurboTechRacing; Nov 3, 2010 at 09:33 PM. Reason: Automerged Doublepost
Old Nov 3, 2010 | 09:35 PM
Thats $475 FREE SHIPPING !!!!
Old Nov 3, 2010 | 09:36 PM
cli3e0339384398jk's Avatar
spec 3+ is good and i bought from ttr. great shipping times and great deal +++ for ttr
Old Nov 3, 2010 | 09:37 PM
raynrishad's Avatar
Here's what my clutch looks like:
So it's a possibility. I have to borrow the mony from my grand mother and I dont want to tell her "oops, I need more"
Old Nov 3, 2010 | 09:39 PM
Cobalt SS 2008-2009 2.0L Turbo Stage 2 Clutch
[SC072-3] $559.99
Click to enlarge
Types of Driving:
Street, Drag, Pulling, Autocross
Features segmented or full faced pure Kevlar disc with steel backing. This lining features excellent drivability like the stage 1, but offers slightly longer life and higher torque capacity. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Best for street, drag, pulling and autocross.
* High clamp pressure plate
* Pure Kevlar friction material
* High torque sprung hub and disc assembly
* Bearing and tool kit
Toast
Last edited by mongorat427; Nov 3, 2010 at 09:39 PM. Reason: Automerged Doublepost
Old Nov 3, 2010 | 09:43 PM
holy ****, what did you do to it, thats the worst ive seen, its wore right off in 2 spots
Old Nov 3, 2010 | 09:45 PM
Thanks!
Lots of power and a bit of slipping...
Last edited by TurboTechRacing; Nov 3, 2010 at 09:45 PM. Reason: Automerged Doublepost
Old Nov 3, 2010 | 09:46 PM
raynrishad's Avatar
Well... Sigh... GM put a brand new trans in it a month ago. Put about 3-400 miles on it and it started smoking on downshifts slightly.... Then it stoped smoking. Took it to the track and blew it up. The guys at the track asked me if I was burning my tires out at the end of the track. YAY me
Popped the hood at the track and wires were unhooked, harness flopping around, they didnt bolt the fuse box back in and they broke some of the clips in it.
Old Nov 3, 2010 | 09:53 PM
jmo2010's Avatar
ya i broke my fw, they day i got my car it was slipping so bad you could barely drive it, like the rpm would bounce up and down like crazyyy...so i took it to dealer and they replaced everything under warranty..Thank god for the warranty because it wouldn't of been cheap lol.
Old Nov 4, 2010 | 05:29 AM
raynrishad's Avatar
Anyone know anything about Clutchmasters? Clutchmasters Stage 4 clutch 08+ Chevrolet Cobalt SS - 08+ Chevrolet Cobalt SS Turbo Drivetrain Parts, Clutches, Axles, Short Throw Shi
Old Nov 4, 2010 | 05:50 AM
Iam Broke's Avatar
He needs at least a SPEC Stage 2+, the Stage 2 will slip. 2+ is rated 437 ft/lbs tq. Stage 2 is less.
OP - I have my used stock setup if you want it, pm me an offer. 20k highway miles but slipped on WOT since tuned for me.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
