Oil Change Help
Old Apr 22, 2010 | 07:03 PM
ISuckBad45's Avatar
Post Oil Change Help
I have searched the "How To guide" section and i was not able to find one for a LNF oil change. I'm sure it's very simple however, i want cross all my T's and dot all my I's. Can someone provide me a link?
Thanks!
Old Apr 22, 2010 | 07:12 PM
F_Imports_09tc's Avatar
It's the same as the lsj one, but lnf's only need 5 quarts. Double check that number as it's off the top of my head, but the lsj uses some ridiculous amount of oil. Otherwise it's exactly the same. Jack car up, drain oil, remove and replace filter, fill.
Old Apr 22, 2010 | 07:42 PM
Iam Broke's Avatar
5 qts. is correct.
Old Apr 22, 2010 | 11:55 PM
kylewalton2007's Avatar
open the filter cap first before you drain the oil.
Old Apr 23, 2010 | 09:11 AM
tmharsh's Avatar
You can make life easier by picking up the oil filter cap socket at an auto parts store. They're over by the oil filter wrenches and will say it's for Ecotecs in the description.
Old Apr 23, 2010 | 09:18 AM
fredds-turbaltSS's Avatar
What? Its a 1ź" socket going to need a nice extension
Old Apr 23, 2010 | 09:21 AM
ssilver's Avatar
x2, get the socket and use an extension and it is easy peasy. Put the socket on the filter first and then attach your extension through the top.. http://www.amazon.com/Lisle-14700-Fi.../dp/B0009OMYAQ
If you have long arms you don't even need to jack the car up. I just reach from the passenger tire to drain the oil pan. 15mm is the drain plug size.
Old Apr 23, 2010 | 09:43 AM
cubaniche's Avatar
^^^x3. Only I drive it up on ramps. Super easy
Old Apr 23, 2010 | 10:03 AM
ISuckBad45's Avatar
I know Mobil 1 is suggested but i have heard some great things about Royal Purple... any suggestions?
Old Apr 23, 2010 | 10:18 AM
ssilver's Avatar
Any high grade synthetic is fine, whatever fits your fancy. I use Mobil 1, just because I always have and it is $22 for 5 quarts at Walmart. The manual has the ISO rating for syn oil, it says any equivalent is fine.
Old Apr 23, 2010 | 10:24 AM
Nighthawk243's Avatar
Just a note that RP hasn't been approved by GM as far as I know.
Old Apr 23, 2010 | 04:15 PM
ISuckBad45's Avatar
Thanks for the info guys!
I suggest the everyone watchs this video... Very interesting RP all the way!
http://www.youtube.com/watch?v=kqvhRi7-iMA
Last edited by ISuckBad45; Apr 23, 2010 at 04:15 PM. Reason: Automerged Doublepost
brandon04
Oct 21, 2015 07:04 AM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
roth
Sep 26, 2015 12:16 PM
