Reverse lockout in first
Old Nov 23, 2020 | 12:14 AM
DeanSsspsh's Avatar
So I just swapped out my transmission in my lnf to 4.05 trans. I also replaced shifter cables and clutch. My problem is I can only shift into first and second if I engage the reverse lockout. Won't go in without it and won't shift into fifth. . Can you put the shifter cables on backwards?
Old Nov 23, 2020 | 12:19 AM
DeanSsspsh's Avatar
If I disengage the side to side shifter cable it goes in every gear fine without reverse lockout
Old Nov 23, 2020 | 08:19 AM
Sounds like the new cables need to be adjusted.
Old Nov 23, 2020 | 12:25 PM
DeanSsspsh's Avatar
Exactly right ECaulk. I adjusted the left to right shifter cable by the shifter & now works flawlessly. Thanks!
stevenferris1
Jun 19, 2017 11:40 AM
sscrazy
May 7, 2013 03:02 PM
Psytocrophic
Jul 5, 2009 11:55 PM
slow_chevy
Mar 14, 2009 12:27 PM
KAB
Feb 5, 2007 11:32 AM
