Should the oil filter be changed more often than the oil?
Old Nov 3, 2008 | 12:17 PM
Zander916's Avatar
I just follow the monitor... TOTALLY unnecessary otherwise.
My Acura said 10,000 miles and didn't even specify synthetic. I used synth though. But I followed the indicator at every 10k miles.
I've never in my entire life (now on my 6th car) had an oil related problem. (or any lubricant related problem.. period) I had the valve cover off of my Acura around 73K miles (for performance mods) and the cams and everything looked immaculate.
Old Nov 3, 2008 | 01:31 PM
gatekeeper's Avatar
Originally Posted by css9450
Change the filter when you change the oil.
BTW the oil life monitor isn't a "sensor", its all done mathematically. It is based on oil temps, RPM, cold starts as well as mileage. You could fill your engine with Pepsi and it will say 100% when you re-set it.
Concur. Just a "for instance" -- I drove 650 miles from East Central Florida to Western NC a couple weeks ago. Straight through with stops only for gas, I only lost 2% oil life. I lost 10% in the following ~100 miles of semi-spirited twisty road driving, with repeated stops and cool-downs in the 30 degree temps.
Summary: Oil life is more a function of duty cycle, than time or distance.
Old Nov 3, 2008 | 04:42 PM
eurochevy's Avatar
Originally Posted by SSpdDmon
Personally, I do the following:
Filter: Change every 3K miles
Oil: Change every 6K miles
It's cheap insurance IMO. My oil life is usually in the 30~40% range once I hit 6K miles. I figure with as hard as I push the car from time to time, it's an acceptable schedule.
Who am I kidding. I don't drive the car without hitting full boost at least once...
That's just overkill...
well its a little overkill but when it comes out its already black..my engine still misfires at idle dealer can't figure it out and only tells me to come back now adays unless i have a check engine light which is once every few months instead of having me come like every 2 weeks complaining so doesn't exactly help the oil with the little bit of blo-by that every engine has when theres unburnt crap going through
Old Nov 3, 2008 | 04:48 PM
blu3_v1p3r's Avatar
Originally Posted by 1WhiteSSTC
if u take the oil filter off it's gunna leak out alot of oil and u won't know exactly how much, so then your guessing how much oil to put back in........get it wrong and i'm sure the car will go BOOM........not in a good way
LMAO if your low on oil... and you pull the dipstick you can see how low you are lol use some common sense here
and it will never hurt to change the oil and filter at 3000 or 6 months. With the synthetic, if you drain it every 3000 and filter it and put it back in it wont hurt anything ether. I change mine at roughly every 3000 I'm at 351xx and in about 900 miles it will get changed again for 12th time
Old Nov 3, 2008 | 05:23 PM
bri2203's Avatar
Originally Posted by Zerort
Agreed!
But. there are plenty of people on this board that will say GM doesn't know anything and they know more - I can't wait to hear all the genius comments that will follow
For the people who think " GM doesn't know anything " Why do you own a GM product like a Cobalt?
Old Nov 3, 2008 | 05:34 PM
Cougarguy's Avatar
and i would like to add that the cartridge can be removed without any oil loss. you guys are silly!
i havent done an LOF on a new LNF though. so don't hold me to that one.
Old Nov 3, 2008 | 05:36 PM
Dayta's Avatar
no it wont,
i forgot to change the filter once, and i changed it like a week later, and no oil came out
chris88z24's Avatar
Big giant fail. I've done it before, several times. It isn't a canister filter like on older cars, it's a cartridge that is designed not to leak oil when changed. I used to change mine at the halfway point but I just don't care anymore and I change it when I change the oil as per the DIC.
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
importkiller
Sep 30, 2015 07:18 PM
grampss
Sep 27, 2015 08:51 PM
roth
Sep 26, 2015 12:16 PM
