Should the oil filter be changed more often than the oil?
I just follow the monitor... TOTALLY unnecessary otherwise.
My Acura said 10,000 miles and didn't even specify synthetic. I used synth though. But I followed the indicator at every 10k miles.
I've never in my entire life (now on my 6th car) had an oil related problem. (or any lubricant related problem.. period) I had the valve cover off of my Acura around 73K miles (for performance mods) and the cams and everything looked immaculate.
Summary: Oil life is more a function of duty cycle, than time or distance.
Personally, I do the following:
Filter: Change every 3K miles
Oil: Change every 6K miles
It's cheap insurance IMO. My oil life is usually in the 30~40% range once I hit 6K miles. I figure with as hard as I push the car from time to time, it's an acceptable schedule.
Who am I kidding. I don't drive the car without hitting full boost at least once...
That's just overkill...
and it will never hurt to change the oil and filter at 3000 or 6 months. With the synthetic, if you drain it every 3000 and filter it and put it back in it wont hurt anything ether. I change mine at roughly every 3000 I'm at 351xx and in about 900 miles it will get changed again for 12th time
For the people who think " GM doesn't know anything " Why do you own a GM product like a Cobalt?
i forgot to change the filter once, and i changed it like a week later, and no oil came out
Big giant fail. I've done it before, several times. It isn't a canister filter like on older cars, it's a cartridge that is designed not to leak oil when changed. I used to change mine at the halfway point but I just don't care anymore and I change it when I change the oil as per the DIC.
importkiller
Sep 30, 2015 07:18 PM
roth
Sep 26, 2015 12:16 PM
